Sick of waiting for ARGOS...can someone confirm these part#'s for OEM bluetooth
211-820-15-64 and 211-820-16-64
Installation is straight forward, but I'll be able to testify accurately once I actually do it...
Gordon
Anyway, once I installed, I paired my blackberry pearl phone which was also easy. However, I am not able to get anything through the mic and speakers. Although I have not yet brought my car in for version coding, according to Lifeguards experiences, he was able to get his to work.
Has anyone else installed yet, and got theirs to work prior to version coding?
I am able to manually input addresses + Phone #s on my COMAND in the SERV menu - Address Book menu.
My Blackberry Pearl's address book does not get downloaded. I popped my SIM card in my buddy's MDA, and the phonebook did not download - What do I have to do in order to get it to download?
Anyhow, Enjoy your BT madness
CAL..Do you have a euro comand? How did you remove the teleaid connection excatly?
Anyway, after about ten minutes fiddling around with this, I decided to just pull out the faceplate part that is still attached to the teleaid connector, and make the drill modifications that way. You have to disconnect to disconnect the false floor from the base plate, via the two prongs. Then you can pull out the false floor far enough away to drill the proper holes.
Put something underneath of course unless you want a few extra ventillation holes in your dynamic seats.
Is it true?
Can I get it installed on my U.S. Car with a Euro Comand in it?
Are there many MBs in Brazil?
https://mbworld.org/forums/w211-amg/186569-v60-bluetooth-phone-adapter-interesting-discovery.html
Good luck.
I haven't gotten it to work yet, although I have not tried again. I will be on vacation for the next week and a half. Then I was going to bring it in for the version coding, and see if that fixes it, or else then have them get it to work.
The puck is definitely pairing with my Blackberry pearl. I am just not getting anything over the speakers, or hearing anything from the mic.
My dealer installed cradle system works well, however my Motorola Benz v710 phone is getting intermittent when in the cradle, due to scoring of the brass contacts. Not looking forward to paying for a replacement.
My wife's car has no cradle install and she uses a different type of phone. Argos might work for her car.
I am using a Pocket PC phone and it works amazing (no phone book although, the most important numbers if previously dialed stay in the command). It is this one:
http://www.ats-systems.com/store/det...UCT_ID=4081327
Thanks to everyone for the thread!!!
Anyone have any ideas why the mic would not work? I'll have to take it back in later when I have more time. But I love how all the buttons on my command now work! I like how you can dial right from the unit--seems cool. I'm real close...
Also, those LEDs DO NOT work with wagons. Jaime was wrong on this one. They tried reprogramming the SAN module and it still did not like the LEDs. Oh well, gotta see if he'll take them back.
If I bought the part and installed the box and the stalk, is that it? Will it work instantly or will I have to get something turned on?
Also, in the PDF, where does the voice control module go? I can't seem to figure out where that goes?
My question is, if I buy it now. Is it a plug and play install or do I need to have something else coded?
Also, do you know where the actual module gets plugged in? Is it in the trunk? The armrest? I can't tell in the PDF.
Let me ask you, when you took yours in for coding, did you tell them you did a self-install and that you didn't install the VCM?
I didn't tell them that, and I think they must have assumed I had all the components installed...
On my pocket pc I picked, send contact info via Bluetooth. It then asked the device and i picked the Mercedes handsfree and then voila, the contact stayed in my phonebook..
So for all of you out there see if there is a way to send your contact via bluetooth and your command will keep it in memory forever.
Pretty cool...
However, I did get one response to an email I sent them through their website.
You might want to try that....
I just sent him the LEDs he sold me which didn't work on my wagon. He didn't return my calls, but when I called the main number, the gentlemen who answered just asked me to send them back, that Jaime was out sick...
