E-Class (W211) 2003-2009
Sick of waiting for ARGOS...can someone confirm these part#'s for OEM bluetooth
Old 05-22-2007, 10:51 PM
  #201
ATS
ATS's Avatar
2004 E500 / 2001 C240
Originally Posted by ludachrisvt
AHA! You have to store voice tags! LOL ... I didnt know that! I was like, why wont it dial a name???!! Now that I know this I will probably use it more.
The reason I say it was sort of a dissapointment is because of the lack of navigation control with it. My last vehicle was a 2004 acura TL. It didn't ride as nice but it came with all of this standard. I could say things like "find nearest <insert whatever>" possibilities included <insert type> restaurant, gas station, atm, bank, shopping etc etc etc
I still like it though. Also, is it normal for the phone system to stay on? I'd disconnect from the system when exiting the car and the phone and car would continue to "re-pair" and transfer my call back to the car. Even after it was locked? Is that going to be a problem with my battery?
I have been having battery problems since I installed this item it seems - the convenience features turned off message. I have been disconnecting the puck when I get home. Even turning the BT off on the phone it seems that others can try and pair.
Old 05-23-2007, 09:33 AM
  #202
Benz-O-Rama's Avatar
My phone stays paired with my car after I pull into the garage, shutdown and go inside. But, it only stays paired for about 2 minutes or so. I guess it takes a few minutes for the car to go to sleep or whatever. No battery problems whatsoever.
Old 05-23-2007, 04:40 PM
  #203
ruffrob's Avatar
2010 Charcoal Grey E350 Coupe
I have a BT Razr,and I accidently hit the phone button on the dashboard,and it says Insert Phone. Does that mean I have the puck installed,and if not,how can I turn this off, and get my regular display back. I've would've had it for five months on 6/9,and am still learning what it does,mainly from you guys. Thanks for any,and all replies received.
Old 05-23-2007, 11:33 PM
  #204
NitroShredder's Avatar
2003 E500
Ruffrob, no you don't have the puck yet... and you would still need it. Lucky for you the 03 and 04 E's have a nice communication module.. so basically you ALREADY have the phone kit in the car.. you just need the cradle for your RAZR or get a v60 cradle and the bluetooth puck... OR to be very soon released "puck with tail." Since your RAZR is supported by MB and AWS if you got the puck with tail and then have your dealer setup your phone to "fitted" in the Star computer (and maybe do a software update to the AGW) you should be live with your bt phone.
Check out the ARGOS thread on this forum and my post on the puck with tail ( or do a search ;-)
Old 05-24-2007, 07:41 AM
  #205
ruffrob's Avatar
Thanks ,Nitro, I appreciate your help
Old 06-05-2007, 09:33 PM
  #206
JoeZ's Avatar
I have an '04 CLK500 and it already has a port under the Tele Aid buttons. Which part would I need then? Just the cradle, holder and puck? Will the part numbers listed on page one of this thread work for the CLK as well?
Thanks all.
Old 06-11-2007, 09:08 AM
  #207
JoeZ's Avatar
^ please advise
Old 06-11-2007, 10:28 AM
  #208
Originally Posted by JoeZ
^ please advise
Those part #'s are for a 2003-2004 W211. Have you called oempartsdirect.com yet? I'd start there.
Good luck
Old 06-11-2007, 12:15 PM
  #209
weinschela's Avatar
'14 E350 wagon; BMW G12 (2020) G01 (2019)
Part No. for "Puck with Tail"
Can someone please post correct part no. for the puck with tail? Can't seem to locate it. Also, is it actually available at Parts departments?
Old 06-11-2007, 06:11 PM
  #210
yikes's Avatar
06 e350 17 glc300
tried emailing oempartsdirect.com to get info on may 31 with NO reply..also tried calling..no one answers... so i guess i have no choice but to wait for argos
Old 06-12-2007, 08:17 PM
  #211
JoeZ's Avatar
Good luck
I've had the same problem as Yikes
Old 06-13-2007, 01:47 PM
  #212
traumatic's Avatar
see the new thread on oemparts!
Old 06-13-2007, 01:58 PM
  #213
hecdog's Avatar
2014 E350 Estate Wagon 4Matic
https://mbworld.org/forums/e-class-w211/197627-oempartsdirect-troubles.html
Old 06-13-2007, 05:34 PM
  #214
JoeZ's Avatar
wow sorry to hear the news on them being deadbeats....
Do you have suggestions for other vendors?
Old 06-13-2007, 06:02 PM
  #215
hecdog's Avatar
Actually, if you read my latest post in the above-reference thread, they've remedied the situation to my satisfaction. It was a mix up and Jaime was dealing with personal tragedy. They've promised to make things better.
I'd give them one more chance. If they don't actually improve, then we'll hunt for another vendor.
Old 06-26-2007, 06:09 PM
  #216
hecdog's Avatar
http://www.eurocarphone.com/index.htm?../news/news1.htm
Anyone see this newsletter from Argos?
I bit late, eh? They're claiming they're 1 month away. That seems like a familiar projection...
Old 06-26-2007, 06:17 PM
  #217
I got the same email today from them. As I've said before, I've heard "next month", "Next Quarter", "Next Spring" for about a year now.
Thank god we figured out how to go OEM for 1/2 the price
Old 07-19-2007, 08:57 AM
  #218
tfulmino's Avatar
First off I want to say thanks to everyone - the information in the forum is top notch.
I recently followed the installation described and I am not getting anywhere. To begin with, I installed the components and paired my phone. All seemed to be ok. Upon bringing my car to MD and being charged $125 - my car still does not work. The MB tech said I needed the Linear Compensator and without that the phone is not going to work.
I found that hard to believe based on what you guys have stated and left pissed off.
At this point the phone is still not working. I am getting the "Please Insert Phone" dialog on the screen as stated.
How can I test the installation on my end? Should I atleast hear the phone through the speakers, etc. I am using a Moto Q phone - not sure if that makes a diff or not.
Any information would be helpfull.
Thanks in advance.
Todd
Old 07-19-2007, 09:36 AM
  #219
Thanks in advance.
Todd
You definitely DO NOT need the linear compensator. I did not install it and mine works fine. It did take the dealer some time to figure out how to version code the car though. The original tech kept telling me that it couldn't be done. Finally, the shop foreman got involved and he had it done in 5 minutes.
What dealer in MD did you take your car to? I took mine to EuroMotorCars-Germantown. Maybe you'll have better luck there.
Old 07-19-2007, 11:35 AM
  #220
tpowel2's Avatar
2013 Ford C Max Energi, 2013 Cadillac SRX
I had the exact same experience! They worked on it for over an hour, came back and said it can't be done. One of the senior techs came over, and was looking at it, he took it back into the bay and had it working in just a couple of minutes... Good luck!
Old 08-08-2007, 10:17 PM
  #221
lasvegas99's Avatar
E500
Originally Posted by MOZART
I bought the V60 puck and cradle on ebay, installed it in 30 minutes, and did the version coding and guess what?.. IT IS WORKING .
I've tried the razor and treo 700p from verizon and they paired and downloaded the phone book easily.
thank you guys for this wonderfull thread, and by the way can someone figure out a way to improve the NAV system.
Went to compatible phones but Sprint wasn't even a carrier option. I see Mozart got the Treo 700p working with Verizon. I got a Treo 700wx from sprint. Anyone know if this should work?
Old 08-24-2007, 05:10 PM
  #222
tfulmino's Avatar
Got mine working.... thanks!
Old 08-24-2007, 07:15 PM
  #223
Outstanding!
Old 08-31-2007, 01:18 PM
  #224
gqmobile's Avatar
2004 E320 Silver/Black Int
I live near EuroMotorCars-Germantown and called there yesterday about installing this device in my 2004 E320. The guy I spoke to seemed to not really understand what I was talking about and told me it would cost $2200. Who's you contact over there? Maybe it's better to buy the part online and just go in for the software update?
Old 08-31-2007, 01:33 PM
  #225
Yeah, it's definitely better to buy the parts and do the install yourself. It's real, REAL easy. The part#'s are stated throughout this thread. Then you just need to take your car to the dealer to get it version coded.
If you still have trouble, PM me.
Quick Reply: Sick of waiting for ARGOS...can someone confirm these part#'s for OEM bluetooth
