E-Class (W211) 2003-2009
Old Jun 10, 2015, 12:35 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Lighting Guides
Print Wikipost
HID, fog lights, headlight install guide 211 E series may work on other series models
Old Jan 7, 2017 | 11:02 AM
  #276
jbeech's Avatar
72 R107, 04 W463, 05 W211
Nigel,
Like everyone else here, over the years I've worked on my back with a crawler (or a piece of cardboard), plus a set of ramps or floor jack and stands - and through every variation of these you can imagine. I'm approaching 60 and recently decided to do something foolish and bought myself an old Roller, which I've admired from afar for a long time (and that my grandson promptly named Tootsie because of her rich brown color).
Anyway, while I long ago learned there's nothing more expensive than buying the cheapest example of a used car and thus, had diligently sought out and bought the nicest one I could find. Not unexpectedly there were still a few things that needed doing toward keeping a near 50 year old car on the road. With that, I splurged on the lift because I decided I didn't want to work on my back any more - do hookers reach this point also?
Meanwhile, the only real sacrifice was making room for Tootsie because I wanted to keep her in the garage next to Mercy (Lynn's MB wagon - her third because she loves the things). My mistake, however, is having a two car garage because I know good and well I'm car queer (and cars tend to multiply). Anyway, I'm fortunate in marrying the right woman almost 40 years ago because she's fine with living where we have a bit of elbow room. This means a large building for my needs.
Thing is, the building is already full because I run my business out of it. Then it occurred to me if I had a lift the sports car could live on it until I have time to put her back on the road (whereupon having just a 2-car garage will once again become an issue). In the meantime, storing Lulu in my building means Tootsie can live in the house - plus I have a lift for when I want to do something ;>)
Attached Thumbnails HID, fog lights, headlight install guide 211 E series may work on other series models-img_2352.jpg
Old Apr 26, 2017 | 06:01 AM
  #277
MotorWerkz's Avatar
E280 W211, X5 F15, X6 F16
I use LED fog light, just like the ones found in modern cars. it's better and less work on the installation.
Old Oct 17, 2017 | 12:05 PM
  #278
mbfanos's Avatar
GL450
If I put the ballast, canbus inside the projector housing, would there be any problems due to heat? Also, on the passenger side, is it gonna be too close to the SBC to cause any interference?
Thank you!!
Old Oct 17, 2017 | 01:38 PM
  #279
AZN Optics's Avatar
SPONSOR/MBworld Guru
Thank you!!
it’s not advisable to put those components inside housing as they rely on engine air flow cooling.
Old Oct 17, 2017 | 09:23 PM
  #280
ps2cho's Avatar
E
Just ordered the DDM Tuning - DDM Plus HID CANBUS Kit H7 55w. Already have the metal clips needed. Hopefully this will work OK!
Old Nov 25, 2017 | 02:32 AM
  #281
Miguel Cortes's Avatar
e350 w211
hid low beam kit from XENON HID.
To put it short.. I also purchased a harness relay because for anti flicker. You install it with the ballasts and bulb. Ground wire and power wire... however with the harness relay installed it flickers on/off when lights on.
Without the harness relay they do work. No messages.
i grounded on left front strut power and since the batter is in the trunk I used 12v from front fuse box power post... what may be my issue? Is that a bad spot for power perhaps? Does the 2009 e350? Have enough power for the ballast that it doesn’t need a harness relay? Idk please and thank you. Any help appreciated.
Old Feb 8, 2018 | 02:37 AM
  #282
NSS1995's Avatar
W164, W163, W220, W211
Removing and replacing fog light assembly and bulb
Please check it out
Old Aug 11, 2020 | 01:28 AM
  #283
IBowlC63AMG's Avatar
2012 C63 Amg / 1999 C43 Amg
Can you tell me which kit i would need for hi/low beams,parking lights, fog lights etc etc for 07 e350 please
Old Aug 11, 2020 | 01:30 AM
  #284
Originally Posted by AZN Optics
Shouldn't be an issue unless the resistance is built in the ballast. If so, heat could easily become an issue. The new Morimoto XB35 kit compartmentalized the components so you can fit slimmer ballasts as described, and leave the canbus component outside where more airflow can help dissipate heat. Let us know if interested.
looking to do high/low beam and fogs and whatever other lights are associated with the front end.. can you point me in the right direction as to what i would need? 07 E350
Old Aug 11, 2020 | 08:55 AM
  #285
NSS1995's Avatar
Hi for the 07 e350 here are the LED lights for the front
Fog Light LED H11: https://amzn.to/3gNRnVp
2825 LED Bulbs( For sidemarkers and parking lot bulb): https://amzn.to/3afqh75
Turn Signal LED: https://amzn.to/2XQxIgb
High Beam LED Bulb H7: https://amzn.to/3kzvNXe (ALSO THE SAME FOR UR LOW BEAM HEADLIGHT BULB IF YOU DO NOT HAVE BI XENON HEAD LIGHTS)
Old Dec 17, 2022 | 09:15 AM
  #286
brewtownwi's Avatar
MB 2007 E350
2007 E350 Exposed Copper Wires
Great write up. My passenger wires are exposed down to bare copper so my passenger headlamp, both fog lights and turn signal don’t work.
Is it hard to replace the wires. Is it a kit? The turn signal on the mirror on passenger side works and all other lights so I’m thinking some sort of relay from the bulb to engine compartment somewhere.
thanks.
mike
You have already rated this thread Rating: Thread Rating: 7 votes, 5.00 average.
