E-Class (W211) 2003-2009
Old Jun 10, 2015, 12:35 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Lighting Guides
Print Wikipost
HID, fog lights, headlight install guide 211 E series may work on other series models
Old Jun 1, 2010 | 10:54 PM
  #151
starbrite's Avatar
2004 E320
Originally Posted by 180
This is for 2004 e320
Low beam headlamp: H7
High beam headlamp: H7
Fog/Driving light: 9006
Silvania Guide
Actually, that guide shows HID-D2S bulb for the low beam, which is an hid xenon.
I believe h7 is a halogen bulb for "flash" function only.
Old Jul 2, 2010 | 12:19 PM
  #152
starbrite's Avatar
2004 E320
This is a first. I had my Xenon headlight assembly replaced, as result of an accident, and the bulb burnt out after about 30 min of use !
Anyone else ever experience this ?
Old Jul 6, 2010 | 11:48 AM
  #153
starbrite's Avatar
2004 E320
Update : the bulb isn't burn't out, as the light is now intermittent. It's back at the shop today and hopefully they'll find the culprit (you just know the light is going to work while they have it) Maybe a loose connection or potentially defective ballast.
Old Aug 1, 2010 | 01:16 AM
  #154
Gynecologist MD's Avatar
Hopefully another MB soon..
...I used a 3700uf(a bmw forum specified this) cap on my 03 c240... I have to turn on the headlights 5 seconds before I start the car, to keep them from not flickering. Anyone have this problem? Are you able to turn on your lights on just as if you had the original halogens??
Thanks!
Old Aug 12, 2010 | 06:17 PM
  #155
michaelle1's Avatar
06 SL55 AMG; 07 GL320CDI; 17 E300W4, 08 ML320CDI, 14 E350A
capacitor wiring
Thanks for the great informations -- one thing I'm not 100% clear -- you mentioned the capacitor should be installed one direction -- in the diagram it shows the capacitor but it didn't show which way the arrow or the flow is going -- positive to negative or vice versa. Maybe I just totally missed it, but would you mind letting me know?
thanks
Old Aug 16, 2010 | 05:48 PM
  #156
daniel_E350's Avatar
2006 E350 (sold), 2008 C350
DDM HID
Sweet write up! Got my kit at DDM tuning with the Error code eliminator kit. will post pics soon
Just ordered my kit from DDM also. Any problems with your install?
Old Aug 17, 2010 | 11:47 AM
  #157
Received the DDM kit yesterday. Installation was flawless and no error messages.
Old Oct 8, 2010 | 10:09 PM
  #158
503benz's Avatar
w211
what bulb type do you use for ur frog light?? i was gotta make m froglight HID too. but not sure what bulb types and or temper. i should use.
Old Oct 10, 2010 | 12:59 PM
  #159
kansansiao's Avatar
The kit looks decent... any issues with installation, bulb fitment or flickering?
Looking forward to your photos. And if you don't mind, can you tell what items I will need to retrofit my 2006 W211 headlights to HID?
Old Oct 10, 2010 | 01:04 PM
  #160
kansansiao's Avatar
Originally Posted by arvindm
Make sure you have the metal clips that hold the HID bulbs securely to the headlight housing. If you dont have these included in the kit, the HID bulbs will not fit the Mercedes headlight housing well!
Mark
Good to know, what brand of HIDs come with these clips?
Originally Posted by d_boy
I use to think the same until I bought a 55w. If you think the 35w is good you'll be amazed with the 55w.. I have a 6k 55w on my E
Do you have any before/after photos? How how does the 55w ballast get as oppose to the 35w one.
Looking forward to pics are reviews... wondering why these kits are going for so cheap?
Silvania Guide
Good info. I was looking for that.
Old Nov 20, 2010 | 02:37 AM
  #161
benjamin9876's Avatar
e350
for 07 E350 headlight low beam,
which bulb should i get?
the H7 or the D2s? what differents? thx
Old Nov 20, 2010 | 03:35 PM
  #162
rsmith7's Avatar
Veteran: Navy
2009 E350 Arctic White AMG Sport package W/ P2 option, 2002 C230 kompressor Coupe
I believe that D2's are only used for factory HID lighting. I added HID's to my 07 E350 using H7 bulbs.
Old Dec 19, 2010 | 05:58 PM
  #163
12hun-e's Avatar
'07 E350
Unhappy advise please
healthservices,
Thanx to your detailed DIY convertion to HID (headlamps & fog), but the only dilemma I can't figure out is how to remove my 07' W211 E350 headlight bulb connected to the head light holder (where the bulb plugs into) while still attached to headlamp unit. I tried turning counterclockwise while facing the rear of the headlamp, but it won't give. While still attached to the headlamp assembly (rear), do we first pull the head light holder (plugs into bulb) out of the connector (metal portion connected between head light holder and bulb) or turn the holder, connector with bulb attach simultaneously counterclockwise?
12hun-e
Old Dec 22, 2010 | 07:19 PM
  #164
t0ast's Avatar
W203, W211, W212
Originally Posted by 12hun-e
healthservices,
12hun-e
With everything attached - plastic wiring harness with wires + metal clip + bulb in headlamp, you twist simultaneously. It all comes off in one piece - then you pull the bulb and pop off metal clip.
Old Dec 31, 2010 | 02:17 AM
  #165
Benzarati's Avatar
2006 E350
I'm trying to replace my front marker lamps on my 2006 E350 but because of the pulse lighting it's not working. Is there any way to get them to work with having to change the settings using the STAR system?
Old Jan 31, 2011 | 04:40 PM
  #166
wbrown8080's Avatar
W211
Any difference?
Is there any real difference in ads on eBay that claim to be for w211 and ones that a little bit cheaper? Sample #1 or Sample #2
Attached Thumbnails HID, fog lights, headlight install guide 211 E series may work on other series models-800_mt_d2_hid_03.jpg   HID, fog lights, headlight install guide 211 E series may work on other series models-completekit.jpg
Old Feb 17, 2011 | 04:29 PM
  #167
AMGE's Avatar
04 E500 Brabus Wagon
HID low beam conversion question
I must have two left hands but on my E211 2004 I get the rubber boot off no problem and removed the stock low beam bulb out no problem... but I cannot locate the two pronged plug after the bulb to plug my red ballest plug into? Any suggestions from those who have done it why I can't find the plug?
Old May 10, 2011 | 10:53 AM
  #168
XLR82XS's Avatar
2006 E500 4matic wagon
Headlights or fog lights?
Old May 29, 2011 | 07:51 PM
  #169
chmercer's Avatar
2006 e55, 2008 cl550
For people with the DDM hid kit - did you get the additional HID harness, or did everything work fine with just plugging into the existing headlight harness?
Old Jun 7, 2011 | 11:58 PM
  #170
jbziegler831's Avatar
2004 E320 Sedan
Need some additional help on the HID Replacement
So, I read, with great interest, the upgrade to HID, but my 2004 E320 with Sport Package already has the HID and the cornering lights. I got the "Low Beam" out message on the Dashboard command center - and went through all the steps as outlined to replace the D2S bulb (Original on the passenger side was a Philips and I replaced with GE - bought two at the local shop, just in case.)
I managed to get my fat hands into the light compartment from the top, and removed the ballast, the bulb (with the small clips - Thanks for that hint!!) and then replaced the clips and the ballast. Then I replaced the dust cap - all looked normal, I used gloves so that I never touched the bulb and was very careful to make sure all the alignments and such were clean...
So, then I turned the car on and got the error message, no light and the same "Low Beam" out message...So, I did the same thing all over again, with the 2nd bulb - and still no joy!
Do I need to reset something? Could the Ballast be bad? Did I screw something else up???
Any assistance would be most appreciated! Thanks.
JZ
Old Jun 8, 2011 | 12:14 AM
  #171
dannieboiz's Avatar
08' S550, 04' E320 4matic, 03' Acura TL-S 6 speed, 1968 Vespa P150
If you got no light and replaced the bulb and it's still dark, check the fuse if fuse is good then ballast is shot.
Old Jun 8, 2011 | 01:06 PM
  #172
2004 E320 Sedan
Cannot find the fuse that might be controlling any lamp, let alone the headlamps...
dannieboiz, thanks for the hint. I looked at the fuse boxes, and the chart, and cannot find any fuse or relay that relates to the lamps, let alone the headlamp. I am scratching my head now! Did I miss something? I have checked the fuses in the passenger compartment (drivers side) and the trunk - no joy there either.
Wow, am I that lame? I see nothing for any lamp at all...Help!?
Thanks - and if it's in the hood area, then I am completely lame! JZ
Old Jun 8, 2011 | 01:33 PM
  #173
dannieboiz's Avatar
i have not look specifically for the headlights fuse but you can easily test for power using a tester (you can get a wand with a light bulb) you touch the neg and pos, if the light light up then your fuse is good. Are you having problems with both side or just one side?
Old Jun 8, 2011 | 02:12 PM
  #174
2004 E320 Sedan
Found the fuse...Looks fine - took it out, replaced...
I found the fuse - it is in the SAM Box in the hood on the driver's side - took some research here on the forum, but found a diagram...The fuse is for both headlights...
The problem is just the right side - I had the entire driver-side light cluster, lamp replaced about two years ago - had an accident with a raccoon and it shattered that light altogether...
So...I am guessing it's the ballast...but now, I have no idea how to find a replacement ballast...And for the right side...I want to get this working, but it's been a time-consuming process, and now I wonder if I should have just brought it in to the shop....
Anything else you might suggest? Thanks again. JZ
Old Jun 8, 2011 | 03:08 PM
  #175
2004 E320 Sedan
Can an HID Xenon Starter Ignitor be bad? If so, how can I test?
So I looked to see if the Starter (Hella 5DD008319-50 Starter Igniter) might be bad...Is there a way to test that without potentially shorting/killing the other headlamp?
If this part is bad, I can find them online, but I wonder if the original is bad?
Any suggestions on that? Or anything else that anyone can come up with...I am getting to the point where I just bring it to my dealer and have them fix it...
Not sure...Thanks...
JZ
You have already rated this thread Rating: Thread Rating: 7 votes, 5.00 average.
