E-Class (W211) 2003-2009
A/C Control Unit change
Old 07-08-2007, 07:02 AM
Piranajoe's Avatar
2003 E500
Can a Air/Con control unit be changed from the standard manual control in a 2003 E320 to the electronic control as attached?
Would it be plug/play or would it give errors since the rear of the car does not have seperate controls as E500?
http://cgi.ebay.de/Mercedes-W211-Kli...QQcmdZViewItem
Old 07-09-2007, 10:54 AM
shtsai's Avatar
2003 W211 E240
It just plug/play , I just changed mine recently with no problem
Old 07-09-2007, 01:06 PM
Diesel Benz's Avatar
Strange, the 4-zone one is even using a different number of sensors. Perhaps it can automatically adapt to the absence of one, or would the intelligence lie elsewhere?
Old 07-09-2007, 01:32 PM
Piranajoe's Avatar
2003 E500
I would have thought the harness connectore may not have been the same with the different zones.
Old 07-10-2007, 10:27 AM
shtsai's Avatar
2003 W211 E240
The harness connecter is the same. just plug & play
my original two zone unit A211 830 00 85
I changed to A211 830 17 90 4 zone unit
it works perfect
Old 09-11-2007, 12:43 PM
Heejin's Avatar
'06 Porsche 997 Black Sport Exhaust, '06 Mercedes E350 4MATIC Iridium Silver Apper+Prem Package
Could anybody please explain how to remove the control unit? I got the part for my E350, but I am not sure how to remove the control unit.
Is it very difficult? Should I bring it to the dealership? Your help would be very much appreciated.
Old 09-11-2007, 03:41 PM
alfcruiser's Avatar
MY12 W212 E350
Looks like you just need to :
1. remove the wood trim
2. remove center speaker grill
3. remove speaker
4. remove center vent assembly
take a look at attached pdf.
-alf
File Type: pdf
Old 09-11-2007, 04:23 PM
kevmac's Avatar
'08 E350 Sport, '03 Lexus GX470
it works perfect
So what happens when you press the "rear temp" button (3rd button from the bottom left)? Plug-and-play is convenient, but I'd rather have dials than non-functional buttons.
Old 09-11-2007, 11:57 PM
Heejin's Avatar
3. remove speaker
-alf
Great, this is what I was looking for. Thanks for the info.
Old 09-12-2007, 07:09 AM
KosherBenz's Avatar
Its big and Grey!
I didnt know this would work. I heard it wouldn't, but i guess they were wrong.
Old 09-12-2007, 12:36 PM
Heejin's Avatar
I wouldn't say they were 100% wrong because some of the function doesn't work. However, I am pretty happy with it Here are some more detail.
- My wife's car is '06 E350 4Matic
- Part # of original analogue control is 211 830 1885
- Part # of digital control is 211 830 1790
- Cost of the part was around $180 including shipping from Germany
Pros
- Nice LCD Display
- Shows air speed in "AUTO" mode which I find it quite convenient
- It adds Celsius which I am more familiar with
Cons
- Air flow direction control does not work
- "REST" button is dummy
- "Rear Air Flow" doesn't do anything
I wanted to get the part for the '07 W211 which is also digital from the dealership. However, I decided to go with this one instead since they quoted me $700 for that part. Anyway, I hope this helps if you are interested in this mod
Old 09-12-2007, 01:06 PM
KosherBenz's Avatar
Its big and Grey!
can you explain this more
"- Air flow direction control does not work"
tks!
Old 09-12-2007, 01:16 PM
Heejin's Avatar
tks!
It looks the term the mercedes uses is "airflow distribution" control. It controls where the air comes out.
Old 09-12-2007, 02:12 PM
MARK CUMMINS's Avatar
209/W210 Estate /W211 modded by MBENZNL
The Early W211s MUST be version coded from the SDS aka Star to Work..Otherwise plug and play
Also On my 2006 W211 we tried to swap it out and it Did NOT work... Without a version code change to make it work
Glad to hear that Some W211s will work without a Version code program change....
Old 09-12-2007, 02:41 PM
Heejin's Avatar
Mark, did you have the problem with "airflow distribution" control or all the functions of control unit? I am curious if "airflow distribution" control could be enabled via SDS programming.
Thanks in advance!
Old 09-13-2007, 11:59 AM
Heejin's Avatar
Here is the little bit of update. It turns out that "Airflow Distribution" control does work. I was confused since Knob on the left(driver side) controls both side and knob on the right doesn't do anything. I guess this makes sense since there is only one "Airflow Distribution" control on the analogue one.
Here is the updated list
Pros
- Nice LCD Display
Cons
- Passenger side "Airflow Distribution" control doesn't do anything
- "Rear Temp" control doesn't do anything
Old 09-13-2007, 12:43 PM
KosherBenz's Avatar
Its big and Grey!
so its only one zone then? no seprte control for the pass side?
Old 09-13-2007, 01:18 PM
Heejin's Avatar
It's dual zone since you will have separate temperature controls.
The bottom line is that you keep all the functions of analogue control with nice LCD. And of course, you can set the temperature to Celsius
Old 09-15-2007, 05:23 PM
Kallekå's Avatar
Electronic Air/AC control unit
Hi
I did the change to the electronic control unit. After the install, i discovered that when i push the auto button, the light in the AC button also turns on. It was not like this with the manual control unit.
Anyone?
Otherweis it works flawlessly.
Kallekå
Old 09-16-2007, 02:08 AM
Heejin's Avatar
Originally Posted by Kallekå
Hi
Anyone?
Kallekå
If I remember correctly, the LED on the AC button was on when I pushed the "AUTO" button on the analogue control unit.
Old 09-16-2007, 02:39 AM
Heejin's Avatar
It looks like the seller I bought mine from is selling the newer unit of which part # is 211 830 1890. It has the "Max Cool" button instead of "REST".
What does button do? Does it turn on the A/C max level? Is this what '07 W211 comes with if it has 4-zone control? I am curious if this would work on mine
Old 09-16-2007, 05:37 AM
Kallekå's Avatar
Thanks. I guess it works as it should then. Like you i also would be interested in the newer unit without the "REST" button. Where did you find the control unit you are buying?
Kallekå
Old 09-16-2007, 02:20 PM
Heejin's Avatar
Kallekå
Search "Mercedes W211 Klimatronic" on the ebay. You should be able to find a couple of sellers from Germany. I bought mine from a seller who has 100% positive feedback. While it took a while to receive the control unit, it was great.
Old 02-21-2014, 11:25 AM
Craftysince86's Avatar
W211
Pros
- Nice LCD Display
Cons
passenger airflow distribution doesn't work meaning we can't direct to the foot wells or the top? if so where is the default set direct the air flow?
Old 02-21-2014, 02:00 PM
Plutoe's Avatar
Received 1,045 Likes on 968 Posts
1999 E300TD
1
Quick Reply: A/C Control Unit change
