E-Class (W211) 2003-2009
Speakers and Extended Warranty
Old Aug 14, 2007 | 11:36 PM
iBenz's Avatar
Are speakers included in the extended warranty??? I remember being told that nither the CD changer nor stereo are included.
My speakers have gone silent for no apparent reason (with some static) be it on CD, Radio or what have you.
Old Aug 15, 2007 | 10:34 AM
Flash Gordon's Avatar
2003 E500, 2004 G35X
My extended warranty is with MB. I am fairly certain that the music system is NOT covered, it covers just about everthing else.
Old Aug 15, 2007 | 03:14 PM
Double Eagle's Avatar
2003 E-500
Flash is right. The MB extended doesn't cover the music, NAv, speakers or the other COMAND functions. This is the MAJOR omission in the warranty.
Old Aug 15, 2007 | 03:53 PM
konigstiger's Avatar
'71 Pinto
What is your model year?
Have any modifications been done to the audio system?
Is the problem intermittent?
How long have you been out of initial warranty (48/50000)?
MBUSA extended warranty?
Did you purchase new, MBUSA certified pre-owned?
Old Aug 15, 2007 | 04:54 PM
whitewagon's Avatar
Aston Martin Vantage, GLE 43 AMG, Volvo XC60, BMW X1 35i, Ram 1500, BMW Z4 35i
This is one reason I opted for an aftermarket warranty...My warranty covers the radio/stereo system and you can get an option for the Nav system for a few $100 more on a 4 year/100K warranty
Old Aug 16, 2007 | 09:01 AM
Skeeter's Avatar
2005 E55, Renntech Pulley, ECU
Whitewagon,
Curious about a few things... Who'd you get your warranty from? Cost? Have you been satisfied with it so far? Are you into the aftermarket warranty yet, or still under your factory?
I'm struggling to find a solid aftermarket warranty. Cost is less of an issue than coverage and stability. I read HORRIBLE things about almost every company I research, but you know how the internet collects negative reviews (even for good companies sometimes)...
Any feedback appreciated,
Skeeter
2005 E55, K1
Old Aug 16, 2007 | 10:21 AM
iBenz's Avatar
Konigstiger,
Well, for some reason all speakers went down. Now only the passenger side speakers work, but only at low volume. Raise the volume high and you'll hear static than it cuts off until you switch off engine for a long while. However, driver's side speakers havent worked since the first shutdown incident. This applies to all -- CD, Radio etc.
Mine is an '04 E.
Bought car new in '04
No work has been done on the system.
Am located in Canada, however we seem to have similar warranty structure.
Shall I take it to the dealer (probably warranty won't cover) or to just a car audio specialist or something?
Can anyone gauge the problem I have?
I doubt all the speakers were corrupted all at once.
Old Aug 16, 2007 | 10:54 PM
'71 Pinto
Konigstiger, Well, for some reason all speakers went down. Now only the passenger side speakers work, but only at low volume. Raise the volume high and you'll hear static than it cuts off until you switch off engine for a long while. However, driver's side speakers havent worked since the first shutdown incident. This applies to all -- CD, Radio etc. Mine is an '04 E. Bought car new in '04 No work has been done on the system. Am located in Canada, however we seem to have similar warranty structure. Shall I take it to the dealer (probably warranty won't cover) or to just a car audio specialist or something? Can anyone gauge the problem I have? I doubt all the speakers were corrupted all at once.
The Audio Gateway (AGW) control module may be shutting down due to overheating as a result the audio system is shut down. Mention MBUSA DTB P-B-82.60/30 SEPT04 to the dealer. If it is found to be the AGW request a goodwill repair because your current AGW is inadequately ventilated due to a design flaw and it has been replaced with a modified part because of this.
Old Aug 17, 2007 | 04:29 AM
iBenz's Avatar
May I ask what that number stands for? Am in Canada btw. Is it a parts number or some kind of recall number?
Also, my service advisor said that by connecting a computer (diognostics) it should probably point out the problem. Is that true?
I have an appointment on the 23rd... and everything you mentioned I'll be passing on.
Somehow, though, I think my habit of raising the volume to the max almost all the time could have suffocated the amplifier or something. But that's just a layman's guess.
Old Aug 17, 2007 | 11:23 AM
'71 Pinto
Bulletin # which should be readily accessible through Star Diagnosis (SDS), even in Canada
Yes, this is SDS
Actually you may be correct. And this is specifically noted in the DTB whereas overheating may be caused by playing music at MAX volume for an extended period of time.
Forward your email by private mail and will, in turn, forward a copy of the DTB so you can have it on hand for the SA. If you would like a copy of your datacard https://mbworld.org/forums/e-class-w211/197184-free-vehicle-datacard.html also include your VIN.
Old Aug 17, 2007 | 12:41 PM
User110's Avatar
2003 Cl 500
Originally Posted by Skeeter
Whitewagon,
Skeeter
2005 E55, K1
i second that question
ALi
Old Aug 17, 2007 | 01:14 PM
iBenz's Avatar
... this is specifically noted in the DTB whereas overheating may be caused by playing music at MAX volume for an extended period of time.
If this were to be the case... it wouldn't require the replacement of the whole command unit, right?
I've sent you a pm... thank you so much!
Old Aug 17, 2007 | 01:19 PM
iBenz's Avatar
... and just to add, the shutdown did happen while the volume was at the max.
Old Aug 26, 2007 | 07:01 AM
iBenz's Avatar
... well, you were right afterall, it turned out to be the Audio Gateway that required replacement.
Everything was done at no cost to me. Infact, the speakers are even more crispier and clearer than they were
Thanks Konigstiger for your help here and via e-mail. You have been more than I could wish for... can't thank you enough
Old Aug 30, 2007 | 05:36 PM
cyclerider's Avatar
Harley-Davidson
I am considering the MB extended warranty, and it clearly DOES cover all of these things.
From the MBUSA website:
"Audio and Navigation Systems: Covers in-dash audio and/or navigation head unit, amplifiers, speakers, factory or dealer-installed Mercedes-Benz CD player and/or changer, navigation CD/DVD-ROM drive, satellite radio components, fiber-optic network components, and antenna systems."
Old Aug 30, 2007 | 09:34 PM
Barry45RPM's Avatar
2015 ML 350
Earlier MBUSA Extended Warranty booklets specifically excluded entertainment & Comand items. Mine was a 2004, and those and other items were excluded.
There are other terms and conditions in the MBUSA extended warranty that vary from State to State depending in which State, the Warranty was issued to.
Old Aug 31, 2007 | 10:36 AM
carpersn's Avatar
2019 Volvo XC90 Magic/Amber, '95 E320 Cabriolet Midnight,'14 GL350 Lunar/Almond was '07 GL320CDI
Not sure of the switch date, but you are correct...Starmark and early Certified Warranties did NOT cover audio, but now Certified DOES cover audio.
Old Aug 31, 2007 | 01:52 PM
Vik888's Avatar
2008 E550, 2012 GL450, 2014 GLK350, 2015 S550, 2020 GLC350e
So for people buying new 08's with factory and extended warranties .. is there anything major NOT covered?
Old Aug 31, 2007 | 04:00 PM
cyclerider's Avatar
Harley-Davidson
http://www.mbusa.com/care/warranty/extended-limited.do
Old Aug 31, 2007 | 05:06 PM
pfphipps's Avatar
2003 E320
I bought the extended warranty for my 2003 E320 sometime in 2003 or early 2004. It specifically excludes the audio and nav system. Since they are covered now according to the MBUSA website, I assume that is the reason that the new extended warranty price has almost doubled from the 2003 price.
