V1 detector mounting
I have it mounted under the mirror and it’s great there.
However, in my E350, I choose to simply Velcro it to the back
of the dash, very close to the windshield. I hired someoene to
run a cord from under the dash up to it. Don’t know where the
wire is attached but I do know that it turns off with the switch.
V-1 is clearly the best. Love the arrows .. showing cop in front
or behind. It’s never let me down yet.
jimm
‘08 E350 Sport, P2, Black/black, Parktronic,
Voice, Bluetooth, Burl Walnut, Split rear seat,
Wood/leather steering wheel
I wired it from the rear view mirror area all the way to the dash cigarette lighter, which is either switched or not-switched, depending on how the fuse is inserted. Where I ran into trouble is that in probing around to find what was power/ground/etc of the lighter's 3 wires, I blew the fuse. That sounds like no problem, but it turns out the owners manual doesn't tell you where that fuse it, at least accurately. There is no mention of a set of fuses under the hood where this fuse is located. My manual said it was a fuse in the trunk fuse panel, which wasn't blown. Took me some meditation time to relax, oh, and a lot of web searching to figure this out.
Otherwise, its a piece of cake. Run the power wire from behind the lighter around all of the inside trim work up to the mirror housing (do a search in this forum for V1 install, which has lots of pictures/how-to).
If I hadn't blown the fuse which threw me off for a while, would have taken all of an hour or so.
