License Plate Bulbs
2005 W211 E320
License Plate Bulbs
Hey All,
Wondering if someone could help me here. Searched, but couldnt find the answer i was looking for. I bought some Polarg M-28 Bulbs to replace the yellowish stock license plate bulbs, and it worked for a day or two, but on one side the plastic cover melted.
So i searched here, and found out that the stock bulbs were 5w vs the 10w polarg bulbs. Ok so now the question is, what do you guys use to replace the stock bulbs? i know you guys dont drive around with yellowish bulbs lighting up the plates.
Im guessing the only solution is to use LED's correct? since they will run at a lower wattage but still give the bright white look. I know some LED's wont spread light as well as others, so which ones have you guys used/ which one works best?
Thanks for the help/info!
2004 E500 Wagon 4Matic
https://mbworld.org/forums/showthrea...=bulbs+license
If not, the main site the poster was directing to is:
>The largest selection of leds is found at http://spectrumled.com/festoon.htm
>They have the resistors you will need to prevent "bulb out warning"
2005 W211 E320
actually not looking for a replacement of a stock bulb, that i can find no problem. I want the bright white look that led's or polarg bulbs give.
2005 W211 E320
Me still have the yellow...sorry! I am pretty sure though that there was a recent thread on these bulbs. Hope this link works:
1 Post
E500,CLK500K, E55
i was reading... if you want to replace the lights with LEDS of any kind you have to wire in an IN-LINE resistor to compensate for its low wattage... if not you will get an error code.
hope that helps
hope that helps
Should be simple, measure the current drawn by the led and install a parallel resistor that makes the rest to reach equal current consumption as with the original bulb. The resistor would have to be of correct size/wattage.
sorry i don't understand the world of electronics. if i was to bring the LED bulb to Radio Shack will they be able to tell me what type of resistor i need?
2014 E350 Sport
I've installed these http://www.hoen-usa.com/licenseplate.htm and they look great. Very simple to install too.
