Complete Brake Failure - 03 E320
The electrical issues should not have appeared if the corresponding recall fix had been done, at least it should have been unlikely.
Seems you did not panic as you figured out to use the parking brakes. Sounds odd if it did not brake at all first but was functional after off/on. Also the brake pedal should not behave differently if SBC brakes work or not, the pedal has a simulated force when the pedal is pressed. Perhaps you mean you did press the pedal with good force, not just with low force, making it go fully down. The pedal should have a "mechanical" backup, the braking force would be low relative to the pedal pressing force but it sounds like you did not feel the backup system braking at all? Perhaps pumping the pedal would have helped but I understand you did not have too much time to try that.
This happened to me also. I had the car towed to MB. Complete sbc system was replaced. I also filed with NTSB as safety issue for them to follow up and track frequency.
My job as customer was not to try and find the root cause failure analysis on the brake system. When MB decided to go with FBW these problems belong to them.
Now as an engineer I would like to know what failed, but I won't spend my time against finding the cause. That's MB's work.
If the Dot 5 caused seals etc to be damaged then you would have a more extensive repair. But I would try the total brake system flush before throwing the baby with the bath water.
FYI it is very possible someone did put Dot 5 in the brake system. I just picked up my diesel truck from the shop that installed a new transmission. This truck uses Mercon III fluid in the powersteering system and brake booster. The pump was screaming at me when I picked it. I checked and the cap was off the pump. At home I did a full flush on the system with the correct fluid and the noise stopped and the system began to function normal. MY guess someone put power steering fluid in the PS pump that requires Mercon III. So if this could happen to my truck I can also see Dot 5 in your brakes. Best of luck and don't be suprised if Carmax denies it also.
If I understand this, was your car was at the MB dealer the LAST time it was serviced? If so AND they stated all recalls/campaigns had been performed, and now they're telling you you have the wrong fluid in the brake system, well, isn't it their fault??
I imagine when an MB comes into the dealer, they make sure the car is up to par in terms of recalls, esp. the SBC system? I don't think they wait for the car's brakes to fail and then repair it free?
At Carmax, I spend 10 minutes explaining the situation with the service guy. I get a blank stare when I mention SBC. They're busy, so they're going to send my car to an independent shop "Norm Baker". After I leave Carmax, I look at the repair order. One line - "Brake failure lights come on".
Oh well...I'll try to explain things to Norm Baker. Maybe they can test the brake fluid to see if it truly is silicone based (DOT 5) rather than glycol (DOT 4). I've use Ate super blue DOT 4 in my BMW (again, haven't touched the Mercedes brake fluid) and the color is just dye.
So, I've learned two things. 1) Extended warranty is a worthwhile investment from Carmax. 2) Never do business with Fletcher-Jones in Las Vegas. That's assuming they were BSing me - a pretty safe assumption.
I've had the car for 1 1/2 years and put on 5,000 miles (car now has 27,000 mi) and I've had the following repairs - which Carmax has covered under Maxcare extended warranty:
1) alternator/ fuel pump - $ 740 parts/labor
2) replaced combi switch (windshield wiper problem) - $ 332
3) SBC malfunction ~ $4000
After deductibles, I'm out about $200, instead of $5000.
MR. TOM DOWNER, COO
FLETCHER JONES MANAGEMENT GROUP, INC.
7300 W SAHARA AVE
LAS VEGAS, NV 89117-2756
Then I go there, a new guy's behind the counter, and wants to charge me $60 something, I tell him the story and he refuses to call the other branch and says they might be quoted me wholesale prices....WHY would they do that? Angered me so much. It's like when you're dealing with such incompetence, you're just so powerless in the situation.
Anyway, congrats on getting it fixed for cheap. I just don't like the way F.J L.V seem to do business.
