Brake Issue Help!
My feeling is that this should be covered regardless of me changing the pads myself. What are your thoughts?
1) Follow the actual MB procedure to disable the SBC w/o the $$ startrek computer
2) After completing 1 disconnect the plug to the SBC unit.
3) Wait about 1 hr to allow all power on the SBC to dissipate. (this will probably happen in 1 minute or so but haven't measured this)
4) Connect the SBC unit
5) Depress brake pedal fully
6) Turn ignition on. ( this will energize the pump and force seat the pads)
7) Check for the warnings.
8) Repeat 6 and 7 about 3 times
Hope this helps. But before replacing the SBC pump I would certainly try this step. Also the way to damage the SBC pump is to push the pistons back into the caliper without opening the bleed screw. If you open the bleed screw when pushing the pistons back into the caliper it prevents forcing fluid back reverse flow to the SBC.
It is possible that some particles went into the SBC and affecting a check valve. Best of luck. SBC replacement (mine was total SBC failure replaced under warranty) was over $4000.
