Should I remove a 1/2 quart of oil?
03 E500 Sport, 03 Eddie Bauer Explorer, 06 Pro Street Chopper
I changed oil in my E500 yeatarday and didn't have my doc's and relied on the old memory and added 8.5qts. After the change the com didn't have an "overfull" error so I figured I'm fine. Looking thru my paperwork I see it only calls for 8qts. should I remove 1/2 a qt?
Thanks,
Thanks,
Yes, overfilling is not good for the engine.
2006 E320 CDi, 2008 3/4 Ton Suburban, 2007 "rice rickshaw" Accord 5 speed
Thanks,
Thanks,
When I did overfill once the engine light came on and the message specifically asked me to remove engine oil so if you have no light you are OK.
Thanks,
Thanks,
MB did not want mere owners to touch their cars. They only wanted authorized dealerships to do so.
Thanks,
Thanks,
I would check from the cluster computer the oil level, if it says it is OK, it would be fine (if it is close, it might give warning while driving). I assume this car does not have a dipstick that could be used to check the level.
E-ZGO 53hp., 1999 E 430 sport, 2004 E 55, 2008 Tahoe LTZ on 24"s
I overfilled my 430 once and gas mileage suffered -5mpg, I guess any oil over the windage tray will hit the crankshaft and cause losses.
I cannot understand why too much too is bad for the engine. Someone here said that it foams too much and reduces the lubricating effects on the engine internals. The owner's manual said not to overfill as well.
If there is to much in the car, the display will say so. If the car says all is well, then it is.
Good point. Reading the original post again, the owner seems to state that the car computer does not claim too much oil (does not ask to reduce oil), it should not have too much oil then. I interpreted the owner confirming that it has half a litre too much oil but he actually was just referring to the amount put in.
Isn't it 8 liters? If so, 8.5 quarts is about right. I might be wrong, though.
In all honesty, you've probably spent more time posting re this than it would have taken to remove the half quart. I say better safe than sorry.
General consensus is to be on the low side vs high side.
