Any advice for removing steering wheel?
I removed one from a porsche once and it was easy. Two screws for the air bag and a large nut for the wheel. Do I have to disconnect the battery?. Any advice would be welcomed. Thanks
Search is your friend. ![Big Grin](https://mbworld.org/forums/images/smilies/biggrin.gif)
I wrote up a how to on exactly this subject:
https://mbworld.org/forums/e-class-w...de-w-pics.html
Enjoy.
Enjoy.
BTW , I did do a search and there are about 150 threads with steering wheel in them, so after 15 minutes and no answer I just thought I would throw it out there. I guess I shouldn't ask questions , I will just spend the evening searching. I won't even ask about 19 rim fitiment because I should search or the clunk when stopping. In fact maybe this should just be a search site. I'm sure every question has been asked , so don't ask search. Ive had just about every car and have been on every site. I forgot the last time I had a Mercedes how impatient your group can be. I will not ask anymore questions. You all can just keep getting pissed about all the questions that should be searched. I appreciate the answer but not the stupid search comment I keep reading on the question replies.
. Later folks.
![off topic](https://mbworld.org/forums/images/smilies/ot.gif)
chris1978 (12-09-2019)
Wow.
Welcome to the board. Not a good way to start if you plan to continue to ask for help here. I'll let this one slide. Maybe you didn't notice the smiley (
), which normally denotes a gentle ribbing, or joke in the forum world.
Hope my write up helps you with your steering wheel install.
There is something else that I accidentally left out in my howto thread. If you don't do this one thing, the airbag can and WILL explode in your face...
...ahh, nevermind. You'll probably figure it out.
So if I am going to swap out the steering wheel, should i disconnect the battery(both?) or can i just follow the steps in your DIY? I asked the Dealership how much to swap one out and they said 150.00. Figured I should just do it myself.
It's a 10-15 minute procedure, if done correctly.
Piece of cake.
I changed my leather wheel for a wooden / leather piece and the idea of working on a small bomb is a little unnerving but I have to hope that triggering the airbag accidentally is somewhat remote. A couple of things I ran into:
1. The torx screws on the rear of the wheel that hold the air bag insert are recessed deep into the padding. I did not have a bit that fits into a 1/4" drive so I had to cut the shank off of a perfectly good screwdrive type torx tool to get clearance between the fasteners and the speedometer glass. Moving the steering column up and down and in and out helps.
2. The center torx that holds the wheel to the column is a big one and it has some kind of locking fluid on the threads. You really have to apply lots of torque to break it loose. This puts lots of load on the wheel lock. Try to get someone with some muscle to resist the wheel rotation. You need an extension to get to this fastener and that makes the force you are applying difficult to keep in the right direction. I cut a v notch stick from the floorboard and nested the drive extension in it.
As others have said, with the right tools, it is not a big job. Be sure to align the wheel on the spline shaft by centering the front wheels and the steering wheels.
As remote as it seems, I would still apply loctite to the center wheel fastener. You don't want to find yourself holding the wheel in your lap ala Formula 1 style.
1 Post
2007 A8L 4.2
What, do you think that he knows the link by heart??? Nope, he took the time to search the forum with keywords that he knew would bring the right answer, then copy/pasted the answer for you to look at. Someone you DO NOT KNOW took the time to lend a helping hand and you come up with this garbage??? I am sure you had a better day after getting the answer to the question you posted.
Anyway, I am sure C does not need anyone to stand up for him, but I really think this was a very ungrateful gesture on your part.
Peace.....
1 Post
2007 A8L 4.2
oooooooooohhhhhh, we are in 2010???? No wonder everything looks different!!!! ![Big Grin](https://mbworld.org/forums/images/smilies/biggrin.gif)
Just realized the date is 2009!!! But anyway, the ungratefulness of this dude just pi$$ed me off......
Cheers!!!
Cheers!!!
