E-Class (W211) 2003-2009
rear washer mod help
Old Apr 8, 2009 | 10:06 PM
shaunls1's Avatar
2003 E500 sport
Wink rear washer mod help
hey guys i went and did the front washer mod to lower the car and it was extreamly easy and it droped the car about a 1/4 of an inch and it looks really good.
now i have to do the rear and i know where the sensor is but i need some help on the process.
help me out guys and ill post up some pics of the washers i used.
Old Apr 9, 2009 | 08:53 PM
shaunls1's Avatar
2003 E500 sport
any one?????????????????????????????
Old Apr 9, 2009 | 10:07 PM
Benz-O-Rama's Avatar
With a quick search of the word "washer", I found these threads:
This one is from a user who used washers on the rear sensor, in lieu of using a dremel to notch it out and reposition the sensor.
https://mbworld.org/forums/e-class-w...ted-again.html
Then there's this one about a W211 who's airmatic failed while lowered via washers.
https://mbworld.org/forums/w211-amg/...-airmatic.html
Be careful. I did the washer method for a couple of months without problems, but I was always scared. If you can afford it, get the RENNtech ELM. With the ELM, you still get the full allowable travel of the suspension, rather than tricking the computer into thinking it's sitting higher than it is, with the washer method.
If you can't swing the ELM, I suggest lowering links. www.adjustableairride.com has a great product.
Old Apr 13, 2009 | 05:35 PM
shaunls1's Avatar
2003 E500 sport
here is a pic of the pulley
konigstiger
