E-Class (W211) 2003-2009
LED lights in the new york area ...
Old Jun 16, 2009 | 09:03 PM
Al benzo's Avatar
2014 E350
Hey any one put on leds on there licanse plate lights in the new york area ???? If so im trying to find some one i can pay to put mine in .... I know it takes a little bit of work >>>
Old Jun 16, 2009 | 09:32 PM
BkE5Kid's Avatar
w211 E500
Cool New York
i would like 2 know this also
Old Jun 16, 2009 | 11:02 PM
SPNJHockey's Avatar
07 E350 4Matic / Sport with P1
Come on guys...it will "literally" take you longer to remove the trunk lid-cover than to do the install!!! And that goes for non-mechanics (like me).
Old Jun 16, 2009 | 11:27 PM
KL2DC's Avatar
W210 E55, W211 E3504M, E90 325i
I'll do it for you for $100
All kidding aside, There's an open and timely discussion in the W211 AMG sub-forum.
They found a nice and tidy plug and play no-error solution:
http://www.ecstuning.com/Search/ES51...aign=postreply
$50 shipped. DIY is as easy as unscrewing the housing covers and replacing the bulbs. Your owner's manual outlines the procedure.
I have this very same bulb type on my 06 325i (apparently there is cross-compatibility). These were the first error-free plug-n-play solution for pre-08 E9X as well (there were many attempts before that).
I just ordered a set for my W211, can't wait to have them as I loved them on my BMW.
Old Jun 17, 2009 | 10:55 AM
Al benzo's Avatar
2014 E350
LOL ok ok I just dont wanna mess some thing up !!!
Old Jun 17, 2009 | 10:11 PM
SPNJHockey's Avatar
AlBenzo...look at it this way...if you do screw it up, you can just cut out what you put in, and splice the oem wires back together!
The LEDs I got from AutoLuminations were supposed to be plug & play too. They are PnP for a lot of models, but for the '07 they weren't. So, I ordered their capacitors which eliminated the error codes, the flashing and not-turning-on at all:
$10 for 2 load equalizers including the wire taps.
$20 for 2 39mm 9-element LED Festoon bulbs.
Good customer service there also.
Old Jun 17, 2009 | 10:45 PM
KL2DC's Avatar
hahaha SPNKHockey, you're scaring AlBenzo.
Hold on for a while until I get them. I'll write a detailed review along with my own install guide/tips. They should be PnP and they should work based on my experience on my BMW (which was a difficult application to begin with).
Old Jun 17, 2009 | 11:47 PM
Al benzo's Avatar
2014 E350
Lol im going to try the plug and play for 50 bucks ... Il see how it works out ...
Old Jun 18, 2009 | 11:41 AM
KL2DC's Avatar
If it doesn't you could always sell it to the BMW crowd. That's my thinking
Old Jun 19, 2009 | 12:22 AM
Al benzo's Avatar
2014 E350
K thanks ....
Old Jun 19, 2009 | 12:37 AM
skokkosis's Avatar
2014 E63-S, 1987 190E 2.3-16, 1985 325E
i can tell you where i got everything from and how i did it just IM me on aim or PM me it was fairly easy once i got all the parts and it cost me about 20 bucks (im from fort lee, nj) right off manhattan
Old Jun 19, 2009 | 02:25 PM
dannieboiz's Avatar
08' S550, 04' E320 4matic, 03' Acura TL-S 6 speed, 1968 Vespa P150
An easier plan is for you to post everything you got up your sleeve here so I don't have to IM you and then a bunch of other guys who are interested is gonna IM you too.
Old Jun 19, 2009 | 04:46 PM
CrimeDoesPay's Avatar
2004 e320
i did mine check my previous threads
Old Jun 19, 2009 | 06:31 PM
skokkosis's Avatar
https://mbworld.org/forums/e-class-w...ml#post3583709
i made one for everyone enjoy
Old Jun 19, 2009 | 07:36 PM
KL2DC's Avatar
So I got the ECS tuning bulbs in the mail today. I rushed out to install it.
DIY is pretty easy so no point going into details. Its per page 446 of the 07 owner's manual. Simple unscrew (2 screws each).
However the lens didn't just drop down on its own. Half the bulb holder assembly is the lens cover itself. I had to use 1 of my plastic interior pry tool to jimmy the lens cover out. Don't use too much force or you'll break something. Just wiggle it here and there and try to pry it loose (I started from the outside first and worked on the other sides in turn).
Once that's out, replace the stock bulb with one of ECS led bulbs and replace lens cover back into the receptacle. Don't screw it back on yet. You need to test it.
Go on and turn on your car and lights. IF the bulb doesn't light up the first time, undo everything once more and reverse the polarity of the bulb (switch it the other way). I had to do this for both side. I guess the W211 is more finicky, I don't remember my BMW E90 being this sensitive.
Repeat for the other side.
The good news is that it works! Pure plug and play!! NO ERROR!!! Another fine product from ECS. Good job.
Now to wait until dark to start taking pics!
So far so good, for those on the fence I recommend you guys look into these bulbs.
Old Jun 20, 2009 | 12:45 AM
Al benzo's Avatar
2014 E350
post link !!!
Old Jun 20, 2009 | 02:24 AM
KL2DC's Avatar
post link !!!
update: finally got to enjoy it in the dark. Wow, its pretty bright. LED bulbs emit a cool 6000k glow around the license plate area. Attached is crummy iphone pic.
