E-Class (W211) 2003-2009
Aux Battery replacement
Old Jun 29, 2009 | 08:32 PM
paulf124's Avatar
I just attempted to replace the aux battery on my 2003 E500
Walmart could not find a Maxx 14-bs agm battery I called and went but ng
I used Vettdrvr s list and had my parts house cross reff and they gave me a Deka ETX-14 agm . Its the righrt size but the terminals are the wrong size. The batt wires have captive bolts and they are larger than the terminals on the Deka.
Has anyone had a similar problem?
Any other sugestions?
BTY when I checked the terminals the ground was loose.
This seems to have fixed the warning message for now but the batt is original and it will go soon so I want to replace before getting stuck.
Thanks.
Old Jun 30, 2009 | 08:32 AM
vettdvr's Avatar
03 E500 and Corvette
Thanks.
The list had only batteries with the +/- in the correct position. Try autozone they have the battery.
Basically it is a 12 ahr agm battery. Not that difficult. If you have the dimensions and location of +/- you can find one on the shelf without any other information. That is how I actually found the first one.
Old Jun 30, 2009 | 08:56 AM
fortlaudsummer's Avatar
W211 Elegance Saloon
The list is good. Stick with one of the batteries on the list instead of playing around with something that may or (more likely) may not work
Old Oct 15, 2009 | 04:49 PM
JeffLewis's Avatar
E500 Wagon 2005 & Porsche 996 2001
Used this site to locate a battery that worked. Ended up using a Sears Battery, and the entire replacement took 15 minutes. The dealer quoted $418 for parts and labor, I did it for $87.99 plus 15 mins of my time. Great forum, thanks for the help.
Old Oct 16, 2009 | 10:15 AM
jimbo1mcm's Avatar
All Diesel Fleet !1983 240d stick,2005 E320 CDI Midnight blue, 2005 E320 CDI, Desert Silver, Kubota
Sears
Battery is a Gold Die Hard Power Sport 14-BS. AGM technology. It might be made by Delphi, but I am not sure. Could be a re-brand. $87.99 plus $5 if you don't have a trade in. Supposed to be a perfect fit, from other forum members. 9 mo. Warranty.
Old Oct 16, 2009 | 04:28 PM
jimbo1mcm's Avatar
Sears Die Hard Gold BS-14
Got two of them today. When I got home, one of them had no acid in the box. Check the box before you take it home!
Old Oct 18, 2009 | 12:48 PM
kenikola's Avatar
2005 E 220 CDI
You will not get stuck if the aux battery doesn't work.
Old Oct 19, 2009 | 03:59 AM
LeviDenim's Avatar
2005 E500 4matic, 99 ML 430, 90 E300
Did you charge it an 2amp or less for a few hours first?
