E-Class (W211) 2003-2009
07 E320 BT: ESP Inoperative message
Old Nov 18, 2009 | 09:34 AM
apl175's Avatar
Just when I thought she was running SOOOOO well...pulled away from the office yesterday and got this nice error..
Pulled over, restarted, and went away. Picture taken to record date/time/mileage in case this needs to become a warranty issue.
2007 E320 Bluetec, 31k miles.
Attached Thumbnails 07 E320 BT: ESP Inoperative message-2009-11-17-18.13.34.jpg
Old Jan 27, 2010 | 11:40 AM
apl175's Avatar
Well it happened again this morning just as I was leaving along with:
- Flashing ESP light as if the system was detecting slip or skid with associated sudden power reduction and/or braking (can't really tell which was happening)
- PRE-SAFE activated twice while this was happening (sudden tightening of the seatbelt)
- After a few seconds of this, the ESP Inoperative message came up again
Going to take it in tomorrow morning....and drive with the ESP OFF for the time being, seeing as how this drive-ability issue could become a safety issue. I'm somehow thinking it's the brake switch, and I was worried that my brake lights weren't working - but they do seem to be. As the car's under warranty, I'll leave it to the dealer.
Old Jan 27, 2010 | 11:47 AM
vettdvr's Avatar
03 E500 and Corvette
Bring your photo as proof it happened. Or you will get one of those "could not duplicate" on the work order.
Old Jan 27, 2010 | 11:31 PM
SPNJHockey's Avatar
07 E350 4Matic / Sport with P1
YEAH...you got THAT right!!! LOL
Old Jan 27, 2010 | 11:32 PM
SPNJHockey's Avatar
But you know...they STILL won't be able to duplicate it. ;-)
Old Jan 28, 2010 | 08:48 AM
vettdvr's Avatar
Perhaps but the dated photo is proof. If it happens more than once you can provide proof and build your case to call MB direct.
Old Jan 28, 2010 | 10:28 AM
SPNJHockey's Avatar
Old Jan 28, 2010 | 04:07 PM
apl175's Avatar
I'm hoping of course, that the error codes will be retained in the fault memory.
Old Feb 1, 2010 | 08:24 PM
apl175's Avatar
For closure:
- ELECTRICAL FAULT SHORT TEST REVEALED CODES: ABR 4BD5, 4B1A AND REAR SAM 9059
- PRINTED FREEZE FRAME DATA AND CONTROL UNIT LOG
- CHECKED CONNECTIONS AT CONNECTOR X62 F FUSE BOX...OK
- ACCESSED B24/15 SENSOR - CHECKED FOR ELEC PIN TIGHTNESS AND CORROSION..OK
- CHECKED CONTINUITY AND IMPEDANCE BETWEEN B24/15 AND X62...OK
- ENSURED B24/15 TIGHTENED TO FLOOR PROPERLY...OK
- REPLACED B24/15 SENSOR...NO FURTHER CODES AFTER ROAD TEST....OK
B24/15 = YAW RATE AND LATERAL ACCELERATION SENSOR-ESP p/n:216-542-00-18
Labour time total = 4.4 hours (straight and non time)
No pricing, because covered under warranty.
Old Feb 2, 2010 | 09:01 AM
vettdvr's Avatar
For closure:
Relatively common problem.
Old Feb 3, 2010 | 09:20 AM
herrakani's Avatar
e220CDI
Seconded, I had mine blown just after warranty expired
