2004 E500 W211 Seat Heaters Blowing Fuses
Does it blow the fuse right away or intermittently?
I am not sure what you are looking for. It is either shorted to ground, shorted to itself, or the wiring going to it is shorted.
I would say unplug it and see ifteh fuse still pops, but these cares are soo damn smart it probably won't energize the circuit after you disconnect the wiring.
Maybe put an ohmmeter on it and then wiggle in the seat and see if it jumps around.
Or test from the element to ground and do the same thing.
THEN
http://www.benzworld.org/forums/w210...er-repair.html
I think it has what I need. Thanks!
Blowing fuses indicate a short not an open.
Fix may be similar just the wire is touching some metal and has not broken yet.
