How to treat a clear coat scratch for a lazy guy?
I have a small 1" scratch on my door. It looks like a clearcoat (fingernail doesn't catch) scratch.
I am a lazy guy with no access to buffers / orbitals. I also don't have a clearcoat pen.
What is the best way to treat this scratch with normal car car stuff (wax / polish / whatever)?
Thanks in advance
I did some web research and I can't get my head around wetsanding the clearcoat / paint off my car. It just sounds like a bad idea
http://www.youtube.com/watch?v=Fk9Pcjgb1z8
Wet sanding, etc., is hardly something a "lazy guy" should be attempting.
Thanks in advance
http://www.youtube.com/watch?v=dVBgDk4Opig
Either way I'll let you know when I patch her scar up.
Either way I'll let you know when I patch her scar up.When you open the box that Quixx comes with you will find a pamplet that contain instructions on how to use the product, two small cotton cloths that are the size but a little bit thicker than fabric softener sheets you put in the dryer, 4 pieces of 3000 grain sand paper (very fine), 1 tube of Quixx scratch remover and 1 tube of Quixx polish. The tubes are labeled 1 - Repair and 2 - Polish so you know which one to apply just by looking at the tubes without reading the label. As you can tell from the picture I also got a three pack of microfiber towels just in case.
The removal of the scratches took a total of maybe 5 minutes. I had a small bowl of water with me that I used one of my purchased microfiber towels to wet one end of it and clean the scratches of any dust/dirt/grime that might still be on it. I used the other, dry, end of the microfiber towel to dry the wet scratch off when I was satisfied with the cleanness level. Next I put a nickel sized wad of scratch repair paste (tube #1) onto the Quixx provided cotton towel and started applying it to the scratched area. I did clockwise rotations while applying pressure and to my amazement the scratches got smaller and smaller with each pass that I did. When the entire scratch was gone I was left with a dull, scratch free surface. I cracked open the polish (tube #2) and again put a nickel sized wad of polish on the other Quixx provided cotton towel and started working on the area that I put the scratch remover on. I used the same method, clockwise rotations with pressure for about a minute until all the polish resolved and I was left with a shinny scratch free surface.
I'm a born skeptic and while I did believe this product would work I was not 100% convinced. Now I'm a 100% convert. Quixx is awesome ! Its a life saver for people like me and it definitely gets two thumbs up; highly recommended !
http://www.amazon.com/GS27-US150208-.../dp/B0007N5848
http://www.asseenontv.com/prod-pages/gs27.htm
Plus someone like me who doesn't know much about paint jobs taking sandpaper to a Mercedes would just not end well
For those using sandpaper. Just remember that it is removing the scratch by removing the surrounding paint...be gentle. Clearcoats and for that matter your basecoat are not thick. If by being heavy handed you remove your clearcoat the only repair is a repaint.
Thanks so much for the great post ! I noticed a nice new scratch on the hood of my car in the garage last night and it's been bothering me ever since. Did some web research today and found out about Quixx. I was hesitant, but I did a search here on the forum and read your post and figured I would give it a shot. Went and picked up the Quixx at Walmart and I just got done doing the repair. What amazing results ! I honestly cannot even tell where the scratch was now. Thanks for the review, you gave me the courage to fix it myself...
Nick
