Suspension DIY Help
Hoping someone can tell me the best way to release the lower rear arm, i am just trying to release the tension on it somehow,
Basically today i tried to replace the rear bushes (putting in adjustable ones for camber correction) anyways after 3 hours of mucking around i ended putting everything back.
Basically the lower arm was under a lot of preload and was thinking people that have replaced their airmatics would have a good way to release some stress from the lower arm before unbolting the airmatic shock ?
Any help appreciated. I then have to work out the best way to press out the old bush
The lower arm i have sitting on a gearbox hoist, while i work on the bush, but was thinking t would be great to get the gearbox hoist out of the way and people that have replaced shocks or airmatics would know whats the best way to get this arm off etc.
Anyways I followed the line and unscrewed it on the otherside, where there seemed to be a bias valve (screwed to the backing of the right rear toe adjuster), and a little air came out but not much and the bags did not go down.
The line that goes into the rear shock goes into it from the side, unless there is another line that comes from the top (in which case this would probably be coming from the boot area).
I will try get some pics up shortly and see if im looking at the correct line.
Thing is you would probably also need to know what voltage and amp to supply before doing it
