E-Class (W211) 2003-2009
Question about Engine Mounts
Old Jun 3, 2010 | 05:14 PM
mohd3333's Avatar
E-240 2004
Talking Question about Engine Mounts
Am having E-240 Model 2004
Last time i had checked the car with MB dealer he advised me to replace Engine Mounts as the engine begin makeing some vibrations.
I will get it replaced soon but i was just wondering what the worst can happened in case they has not been replaced ??
Old Jun 3, 2010 | 05:24 PM
mikekuriger's Avatar
2010 C63
The worst is the mounts fail completely. The engine can hit the hood and dent it, and could also bang the oil pan into the lower crossbeam which would crack the oil pan open.
This has happened to me and friends in the AMG group.
Old Jun 3, 2010 | 06:47 PM
RichardM98's Avatar
98 Brilliant Silver E320 Wagon
Not likely. The design of the motor mounts pretty much ensures that the engine will shake rather violently long before they fail catastrophically.
When the internal bladder in the MM fails that side of the engine drops about 1/2 to 1" and vibration is transmitted thru the chassis and felt in the steering wheel. Most of the mount is metal and maintains the connection.
There isn't much risk driving until you can get them replaced. Mostly the irritation of a rough idle while waiting at the light.
Dealers charge quite a bit for MM R/R. My local dealer charges $700 for an E-Class. You can buy the exact same MM (Lemmfoerder) for about $65 each. Your mounts are a little more expensive. About $90. But there is some hassle getting them in and out.
Old Jun 4, 2010 | 09:05 AM
vettdvr's Avatar
03 E500 and Corvette
Correct. I have already had mine replaced at 87,000 miles E500
Old Jun 4, 2010 | 12:04 PM
2010 C63
You both are incorrect. The motor mount on these cars is a hydraulic shock. When it fails, it can come apart completely and nothing is holding the motor in at that point. I had this condition on one of my mounts - when I went to jack the motor up the mount fell apart completely. Only my driver's side mount was still holding the motor in. My friends CLK55 had 2 completely bad mounts and his motor dented up his hood pretty badly.
Please do not discount the importance of changing these mounts!
Old Feb 26, 2011 | 01:38 PM
jasy's Avatar
e500
thanks for all the valuable info, can anybody suggest where i can buy engine mounts for e 500 2004. the dealer gave me quote of 1000 plus, but you mentioned that i can buy them for 90 dollars, wondering where can i buy them, thank you in advance, i appreciate your replies.
Old Feb 26, 2011 | 02:16 PM
konigstiger's Avatar
'71 Pinto
Front left OEM part # 2112400517 (for comparison shopping, autohausaz.com $90.12 / parts.com OEM 100.05), right 2112403017 (74.55 / 98.90), and rear 2202400218 (17.39 / 31.05).
Old Feb 26, 2011 | 02:21 PM
jasy's Avatar
e500
thanks a lotttttt appreciate it KONIG
Old Feb 26, 2011 | 06:24 PM
jasy's Avatar
e500
thank you KONIG, Little confusion forgive my ignorance, dealer said both engine mounts need to be replaced cause their status is fail, so for 2004 e500 there are total of 3 engine mounts?
Old Feb 26, 2011 | 06:45 PM
'71 Pinto
Left & right lower side of engine and one to rear engine cross member.
Old Feb 26, 2011 | 06:47 PM
jasy's Avatar
e500
thank you
Old Feb 27, 2011 | 03:13 AM
Dan Wang's Avatar
E320CDI, CLK55, and a Smart
Will E55 motor mounts work on a E350? I would assume they are beefier than the stock E350 or E500 for that matter.
Old Mar 17, 2011 | 09:56 PM
jasy's Avatar
e500
Konigstiger,
dealer said that my secondary air pump is faulty, needs to be replaced with fuse and relay? i found bosch secondary air pump on e bay, but wondering about fuse and relay? anybody has any suggestion what kinda fuse and relay i have to buy for secondary air pump?
