E-Class (W211) 2003-2009
Rotating Tires
Old Jun 12, 2010 | 10:26 AM
mtrevelino's Avatar
2006 E320 CDI
Rotating Tires
Such a simple procedure, but how do you do it at home? Looking under my 2006 e320 I see what looks like a full plastic pan and four jack points.
With my old Volvo I was able to jack up a corner in the front and place jack stands on the frame. For the rear, when I jacked up one side, the other rear wheel would come off the ground. This would allow me to rotate the tires.
So, If I jack up a corner of the car using the jack point, is there anywhere to place the jack stands?
Otherwise, it is off to Costco and let them deal with it.
Thanks everyone!
Mike T.
Old Jun 13, 2010 | 07:59 AM
Tjdehya's Avatar
2023 AMG EQS
Yea or you could do what other non Volvo owners do and use the spare tire, its not that hard.
Old Jun 13, 2010 | 09:03 AM
Firestopper0383's Avatar
2014 E-350W4
Why bother...take it to a shop and have them do it, cost should be no more than $20 - $25.00. And if you are real nice to them, they might even check and adjust your air pressures for free.
Old Jun 13, 2010 | 09:28 AM
mtrevelino's Avatar
2006 E320 CDI
Thanks guys! I will just let Costco do it. On to a follow-up question, how (or where) do I place jack stands under the front in order to change the brakes?
Mike T.
Old Jun 13, 2010 | 09:07 PM
lkchris's Avatar
'10 CL550, '12 GL550
Mercedes are not designed for use of jackstands.
Old Jun 13, 2010 | 09:54 PM
mtrevelino's Avatar
2006 E320 CDI
By chance, is there a center part to jack the car up and then place the jack stands under the jack tabs? Or, is there any other option to get the front end off of the ground without having to use two hydraulic jacks?
Thanks again!!
Mike T.
Old Jun 14, 2010 | 09:45 AM
vettdvr's Avatar
03 E500 and Corvette
Perhaps not but I modified my stands with a 2x2 aluminum block that exactly fits the jack pad on the car. Then bolted the block to the jack stand and I use them all the time now.
Old Jun 14, 2010 | 05:54 PM
Efivehundred's Avatar
06 E55(SOLD), 03 E500(SOLD)
Where do you jack the car at the front and/or the back to get the jack stands under the pads?
Old Jun 14, 2010 | 06:21 PM
health services's Avatar
see the rectangler block?
Click to enlarge
There
Old Jun 14, 2010 | 07:25 PM
Thanks for the pic.
What about the rear of the car?
Old Jun 14, 2010 | 10:17 PM
Been a while since I've been back there but I think I used the pumpkin/differential.
Old Jun 17, 2010 | 01:32 PM
HE22WA's Avatar
W211 E320, W209 CLK 200K
Thanks for the pic.
I usually jack right under the diffs=)
Old Jun 17, 2010 | 02:44 PM
06e320cdi's Avatar
2008 ML320CDI
I only rotate them once a year. I have snows for winter and when I put them back on in spring they are rotated. 95% of my driving is highway, I can get upwards of 50k or more out of a set of tires..
