E-Class (W211) 2003-2009
Motor Mount
Old Aug 24, 2010 | 02:23 PM
rontnak's Avatar
2003 W211
Motor Mount
From experience, which is the easier of the two motor mounts to replace yourself? The driver or passenger side? I have already replaced the transmission mount myself, whcih was very easy.
Old Aug 25, 2010 | 05:11 PM
vettdvr's Avatar
03 E500 and Corvette
I was lucky mine failed in warranty. So I didn't have to change them. Next time probably will. Be sure to take pics and post how to do it.
Old Feb 17, 2011 | 10:24 AM
dsm2925's Avatar
W211
So, is drivers or passenger side easier?
Old Feb 17, 2011 | 10:28 PM
rontnak's Avatar
2003 W211
The passenger side is easier due to not having the steering shaft in the way. From trial and error you have to remove the exhaust from where it connects to the manifold and then remove the exhaust all the way up to the middle brace where both of the exhausts pipes are closest together. Once you are able to move the exhaust back a foot or so back you can easily reach the top motor mount bolt. The bottom motor mount bolt is very easy to remove. It should take you 10-minutes to remove the old mount and install the new mount. Note that you must use a jack under the the transmission pan with a 2x6 as a form of cushion when you lift up the engine slightly to remove the motor mount. The most time consuming part is to move the exhaust.
Old Feb 18, 2011 | 06:40 PM
dsm2925's Avatar
W211
only 10mins to replace.. wow
Old Feb 19, 2011 | 02:02 PM
gaazmon's Avatar
2009 SL550 Roadster Diamond White, 2008 CLK550 Coupe Obsidian Black
such a common problem. mine have been replaced twice already and i only have 82,000 miles
Old Feb 22, 2011 | 03:16 PM
dsm2925's Avatar
W211
What these motor mount cost?
i see a set of 2 selling on ebay for less then $100/- possibly cheap materials
Old Feb 22, 2011 | 04:01 PM
Mackhack's Avatar
Dude, your clear side markers look good. Did you put stealth bulbs in too?
Old Feb 25, 2011 | 09:40 AM
dsm2925's Avatar
W211
