New e Owner with Troubles
I think this has been discussed before and a search of this forum will have some good information. Also, have the codes read to determine what actually caused the CE light.
As soon as you burn thru a half a tank of gas, fill it with the highest octane you can find to average out and elevate the octane level of what's in the tank. Do that twice, then run it out and fill with Premium.
Almost everything can can go wrong with these cars is recorded by the car's computer system & can be diagnosed by the dealer.
Since regular tends to have a bit less detergent in it than premium, you may suffer more carbon build-up over very long term use. Throw in Techron every now and then to deal with that.
You are not going to damage the engine and you are not going to see a warning light.
The warning light is classic loose gas cap or worn out o-ring on the cap. It will turn itself off after a while once you tighten the cap or replace the o-ring.
Wait a minute, we are not talking about rot-gutt sub-regular as is supposedly found in Mexico, are we? That stuff is supposed to be so bad it might actually damage an engine.
- nopcbs
It will certainly do no harm in a gasoline engine. It will clean up an engine with fouled injectors with continued use.
Good stuff. Not cheap, though.
- nopcbs
My 74 e9 CSA will run just fine on this gas
If you were unlucky enough to buy gas with a lot of water in it, not impossable in winter where it's cold, that might cause a rough idle. Not very likely, but not imposable. The rough idle is NOT a symptom of too low octane as in regular gas. If you are going to see a symptom (pre-ignition) it will be under load at high speed...and your knock sensor would have to have gone deaf.
- nopcbs
- nopcbs
Loose cap will trigger light. Drive a while it will go off. Don't need dealer.
But if you don't want to trust me on this, then call: 1-800-FOR-MERCEDES (1-800-367-6372)
btw, gas in Mexico is actually good quality. Magna Sin (green label) is like 91 octane here in CA. They have a higher octane available called Magna Premium (red label.)
PEMEX is a state-run company and there is nothing wrong with their product. And PEMEX run gas stations are the only stations in Mexico. The only exception is buying fuel in the middle of nowhere where they don't check the tanks and might have debris (if you're exploring distant rural areas, then carry an extra fuel filter just in case.) I lived in Sonora for two years driving a BMW with no fuel related issues ever.
The "knock sensor" thing is NOTHING but belief. You know, like "legend," old wives' tale," "rumor," etc.
Doesn't happen.
Find the Mercedes documentation.
In Star DAS there is even a test for the knocking tendency of engine. It knows is whether the car is detonating or not, it pulls timing. If you run lower octane it retards timing to protect from knocking based on detonation. Why do you think Renntech and Kleemann remap the ECU for higher octane with their tunes.
#W0133-1778062 Mercedes Benz E63 AMG Knock Sensor Bosch
E350 4Matic06 Ignition Knock (Detonation) Sensor M272.972
E350 4Matic07-09 Ignition Knock (Detonation) Sensor Engine Desig: 272.972
E350 Base06 Ignition Knock (Detonation) Sensor M272.964
E350 Base07-09 Ignition Knock (Detonation) Sensor Engine Desig: 272.964
E550 4Matic07-09 Ignition Knock (Detonation) Sensor Engine Desig: 273.962
E550 Base07-09 Ignition Knock (Detonation) Sensor Engine Desig: 273.960
E63 AMG07-08 Ignition Knock (Detonation) Sensor
