2009 E350 wheel - Tire need help
I have E350 2009 sports package looking to get these wheels from brandnew E550 2011
Can someone tell me if this will fit on my car please..
i have 18" amg sports package wheel 5 spoke oem came with the car..
looking to buy theses brandnew he is going to use custom wheels does not want the oem wheels...
size he has is
I have a set of new 2011 E550 AMG 6 SPOKE SPLIT WHEELS
FRONT- 18 X 8.5 ET48- PART # 212.401.2302 with Pirelli P Zero 245/40/18
REAR- 18 X 9 ET54- PART # 212.401.2402 with Pirelli P Zero 265/35/18
he is asking $1400
please advise as will this fit ?? and do i need TPMS ?
size he has is
he is asking $1400
09' E350 AMG Sport, 09' C300, 03' Honda S2K
size he has is
he is asking $1400
size he has is
he is asking $1400
Administrator
P.S.
TPMS was mandatory since MY08. Only need to transfer if removed by seller.
Thanks for the reply guys but i am confuse tire size is the same and wheel bolt pattern i don't know ?
You guys are 100% sure this will not fit,,,
2009 E350 amg sports package
is my wheel size 18 x 8 or 18 X 8.5 5 bolt 112 ?? tire size is the same...
thanks
thanks
It is a common misconception that if the bolt pattern is the same and the rolling diameter is close, the wheels will fit. Offset is just as important. Get a stick that will fit across the back of the wheel. Measure the distance from the back of the wheel to the portion of the wheel that bolts up to the hub. Do this with both sets of wheels. That will show you the difference, if there is one, and if it's more than a few millimeters you will either be unable to mount the wheels, or will need spacers. I don't know for a fact there is a difference, but it sounds like the previous posters do.
Thanks for the reply but i am completely lost in what you are saying...
i thought either they will fit or not ? were is the standardization gone ??
18" wheel 5 x 112 then i read 18 x 8 or 18 x 8.5 why they make it so hard....
i guess i will have to go to the dealer and ask them what is my wheel size and bolt pattern
thanks guys i am glad i asked before the purchase i would be $1400 out of pocket....
As the Moderator stated above, charliele729 response is incorrect.
I just want to add a bit info to Moderator's info. As he correctly stated, the wheels will not fit as is. However, these wheels will fit without any issues, but it will require using 10mm H&R hubcentric spacers upfront and 15mm H&R hubcentric spacers at the rear (you will also need corresponding 10mm longer (38-40mm) and 15mm longer (43mm) than stock (28mm) bolts). Tire sizes are identical so you do not need to do anything. Also, TPMS in W212 are not compatible with W211 and vise versa - you'll need to remove your sensors and re-install them on to the W212 wheels.
Of course why you would want to do all the above is a different matter all together. IMO, W211's 5-spoke AMG wheels look a lot better than 2010's 6 double spoke AMGs or 2011's 5 double spoke AMGs.
Thankyou so much i will not go with this and you are right 5 spoke is nice..
i damage my rimm and tire right side after going over big pot hole. dealer said rimm and tires for your car $1900.
then i thought well i can get a brand new set for $1400 all matching and new.. This was my reasoning behind getting new wheels and tires..
I will look for amg 18" 2009 wheels and tire set so that way i don't have to mess around with spacer's and bolt ...
picture is what i have currently
Wow you guys are amazing thank you life saver
educate my self every day...it true what they say you never stop learning
I would suggest the following:
1. For the future (starting next fall), get yourself a dedicated 17" snow tires/wheels package.
2. Check eBay for your exact wheels. There are a lot of listings for them.
'03 ML500, '07 E350 Sport (wife's)
Love your 5 spoke amg rims. Hate my 10 twin spoke rims that came on our 07 Sport. Ok look but impossible to keep clean. Good luck with the replacements. Yes. Great info here. Thanks to all!
Trust me every week i have to clean the wheels, Best thing is i have a dealer 2 miles away from my house i take it there every saturday morning for a wash free. i pay the valet guy $5 he vacuum - wash and make sure he cleans the wheel and tires..
