What did you do for your W211 today?
#777
2013 ML350 Bluetec
Worked the poor man's audio into the COMAND head.
I took apart the glove box enough to plug into the AUX plug, and threaded the cable back behind the box, behind all the plastic work on the interior, and now it comes out the ashtray door along with a USB charger cable. Pandora is now an option through the system. The aux cable in the glove box is only visible in the nook the jack is in.
Yesterday, I repaired the splash guard behind the valence panel under the front bumper; the previous owner had hammered it against the pavement far too many times and it was held on with a zip tie. I also replaced the thermostat, and now the car gets to the 92 degrees C it is supposed to instead of barely reaching 50. Yes, I see better mileage now too - that repair will pay for itself fairly quickly.
The more I dig into this car the more respect I have for the designers. If you take a moment and think about what they were trying to do, very nearly everything is repairable by the owner. The same held true for my '85 300D, and the same is proving true for this '05 E320. Love it.
#778
I actually was rooting for Denver. Until Cam is on a team that isn't top 5 in defense, he will not get the benefit of the doubt from me. Every year he's been in the league he's had a outstanding defense. With that said, if I was a quarterback and knew my defense could win games for me, i would have a big mouth and talk a lot of smack just like cam. Peyton however needs to retire!
#779
![off topic](https://mbworld.org/forums/images/smilies/ot.gif)
#780
#781
Independent shop did all of it, friend of mine owns it. The only time the dealer ever touches my car these days is for warranty work like the fuel sending unit.
#782
Added chrome door handle inserts. Still not completely convinced I did the right move. My wife is using my car to commute a lot now (our GL is leased) and her finger nails are scratching behind the handle pretty badly.
#783
2013 ML350 Bluetec
Installed front seat covers and replaced glow plug #3 on my car. Glow plug was way easy, and I put some antiseize on the threads for the inevitable next time. The seat covers were a bit of a pain: had to take the seat backs off to get the headrests out of the seats but it wasn't tough to do. Getting the seat (seat, not back) covers anchored under the seats and under the seat front cabinet took a bit of contortion, but it'll be worth it. They look tight and the passenger one covers a poorly done repair from a PO where they had sliced the middle of the seat for an inch or two. The seats are a bit more comfortable than sitting on bare MBTex now too.
#785
Finally after a lot of research purchased a quality cover and wish I had done it earlier. I hate dust with a passion and I'm in hell until I get some cladding up at the new place. So cover went on like it was custom made for the car and 8 days later as I was taking it off I just folder it up (all sides) onto the roof and put it in the boot. Took me all of about 2 minutes and the car shined just as it did when cover went on. Really impressed with the quality and finish.
Stormguard fully waterproof by Autotecnica
#786
replaced the plastic covers over the seat rails. The rear rail covers were broken and looked terrible. Cheap fix with great results.
This week I also purchased the foam canon from chemical guys, and their soap. Used it once, worked perfectly and was fun to use. Touchless wash. Only had to dry. HIGHLY recommend this...... and a power washer.
#787
Researched new brake pads, rotors and sensors. Can someone kindly tell me based on my 2003 MB E320 VIN if the p/n's are correct? VIN WDBUF65J03A221017
Front Right Sensor 211-540-07-17
Front Left Sensor 211-540-17-17
Right Rear Sensor 211-540-17-17
#788
#789
'99 CLK/05 E500 WAG
Brake wear, visit shop display came up Wednesday, but because of long work didn't get a chance to swap out part until today. Read a fellow member problem, which as they noted was pretty much on point.
$22.00 , about 30 minutes to install. The hardest part is twisting your body under the streering wheel.
#790
Front Disks - 2114210812
Front Pads - 0044208720 - looks like this comes with the sensor. I just now recalled that when I ordered these pads they did come with the sensors. I have extra sensors because of this.
Rear Sensor - 2115401717
Rear Disks - 2114230712
Rear Pads - 0074201020
#791
Thanks. Are there alternate part numbers for the pads?
Front Right and Left - 2115401717
Front Pads - 0044208720 -->> 003-420-99-20 ?
Rear Pads - 0074201020 -->> 004-420-44-20 ?
#792
Your numbers have probably just been replaced by the newer number. both seem to be the same.
#794
Received 4,435 Likes
'71 Pinto
jhorandc (03-16-2016)
#795
A few online sites find the Rear Disks p/n 211-423-07-12 but list the following below. Is this also just a newer part number?
BRAKE DISC UNVENTED
Part Number: 000-423-10-12-07
BRAKE DISC UNVENTED
#797
2011 GL 550, 2010 MB S550, 2004 BMW 645Cic 1988 Corvette
Put yet another new set of wheels and tires on. This is the third and final set. I had beautiful stock 18" chrome wheels and Continental tires. After going through 6 tires in 18 months and bent rims that became to far gone to fix yet again I went down a size to 17's and went with Generals. Much less expensive and a lot less road noise. Needed a wheel beaing as well. Car rides much better, but I don't really care for how it looks. The car doesn't stand out any more. It looks muted. However, my wheel options in that size for the money I was looking to spend was limited.
#798
S211 E350 wagon, w211 e550, 2023 glb250, 2013 Audi q7
AMG 6/4 POT CALIPERS ON 4MATIC DONE!!
FINALLY!!
And not possible without the help from a few members on the board!!
I will put details and pictures up, also with part numbers for installation on the 4matic in a new thread.
CMRIV!!!
ZAYED!!!
With out these guys I would have spent a lot more time and money. The help I received is beyond a simple thank you as NO ONE agreed these would work on a 4matic
TEASER
CMRIV!!!
ZAYED!!!
TEASER
![What did you do for your W211 today?-bfe8cf0e-2d68-4fdc-98b2-1e35c1d9aae1_zps5ah6ljvq.png](https://mbworld.org/forums/attachments/e-class-w211/368956d1542319259t-what-did-you-do-your-w211-today-bfe8cf0e-2d68-4fdc-98b2-1e35c1d9aae1_zps5ah6ljvq.png)
The following 3 users liked this post by W211_350WagoN:
#799
FINALLY!!
CMRIV!!!
ZAYED!!!
With out these guys I would have spent a lot more time and money. The help I received is beyond a simple thank you as NO ONE agreed these would work on a 4matic.
CMRIV!!!
ZAYED!!!
#800
Restored headlights (3m kit plus spar urethane sealer) and troubleshot windshield washer problem to most likely be the pump. Ordered new pump. Wasn't fun because the wheel did not want to come off (lots of kicking was involved)...
Also ordered new cowl as the rubber is almost gone on mine.
