E-Class (W211) 2003-2009
Battery Protection Conven. Functions Tempoarily Unavailable Messge???
Old May 10, 2011 | 03:10 PM
busaman's Avatar
2003 E500 Sport
Car is a 2003 E500 Sport. This error message has come on a few times. On one occasion the vehicle wouldn't start for 30 minutes. Any ideas what it is? Both batteries were replaced a little over a year ago.
Attached Thumbnails Battery Protection Conven. Functions Tempoarily Unavailable Messge???-w211-error-message.jpg
Old May 10, 2011 | 04:58 PM
RA72825's Avatar
I'm going to say that you only think both batteries were replaced....
Have your electrical system checked, something is either draining your new batteries or they are not being adequately charged.
Old May 10, 2011 | 05:06 PM
busaman's Avatar
2003 E500 Sport
I personally replaced both along with my crank shaft position sensor. Thanks though.
Old May 12, 2011 | 10:01 PM
starbrite's Avatar
2004 E320
Check the battery control module.
Old May 13, 2011 | 02:18 PM
bailey55's Avatar
2004 E500
I had this happen a few times when both batteries were only a year old. Convenience features message would go off after about 4 minutes of driving. Then one day the red battery warning--see shop message came on. The battery control module was replaced, and the problem hasn't reoccurred.
Old May 15, 2011 | 10:45 AM
Racin_fool's Avatar
2008 E63 wagon (1 of 62)
I've personally seen multiple battery control modules fail, but I also have reprogrammed many of them since a software update is available using the SDS.
Old Aug 8, 2011 | 07:58 AM
zemun1234's Avatar
2005 E320 CDI (sold); 2007 R320 CDI (sold); 2008 ML320 CDI; 2014 ML350 Bluetec
How much is (battery control module) fix ? I found interesting car with this message on display and I am wondering if it is worth consider it ?
Old Aug 8, 2011 | 12:48 PM
spinn's Avatar
2004 E500
I got this message one midday after I forgot to turn off my headlights in the morning. Unfortunately, I didn't realize the headlights were left on all day til my battery died late in the afternoon.
Old Aug 8, 2011 | 11:57 PM
haris12's Avatar
E320
this basically means your battery charge is low on one of the batteries and voltage dropped below 11.5v i believe so check your batteries.
Old Aug 9, 2011 | 12:23 PM
zemun1234's Avatar
if it is just battery, I think it is easy fix but I read some posts about battery module and/or alternator should be replaced.
Old Apr 5, 2024 | 02:31 AM
NorsemanE320's Avatar
MB E320CDI
I`ll wake this tread up again.
My 2004 E320 Cdi had a waterleak in the drivers footwell, and start giving me alot of electrical error messages.
The car is now dried up, and the leak is fixed.
Most of the error messages is now gone, but there is still a couple. One of them is the "Battery protection conv functions is temp switched off." This comes after 30 seconds after start. Both batteries are rather new and fully loaded.
My indy garage think my Central gateway module is faulty. This because of the amount of error messages i had (SRS, Brakelamp, doorlock driver side, high frequent sound from the Comand audio, battery protection). I questioned if its not the Battery module, but he think thats ok.
So i guess my question is if some of you have any experions or advice in my case? Can the CGW cause all this eletrical failures?
