E-Class (W211) 2003-2009
broken motor mount E500
Old Sep 17, 2011 | 07:01 PM
chrisdagge's Avatar
E500
Somehow i managed to break my motor mount i didnt know what it was for a while but i found it out now. where is the mount locaded at im guessing under the motor because i dont see any mounts on the sides? also if i took it in to a shop how much do they ushally charge to swtich it out?
Old Sep 17, 2011 | 07:24 PM
E500 AMG Sport's Avatar
It's not that you broke it, they are liquid filled and they leak (fail) over time and then you experience the vibrations and the associated awful noises.
Any mechanic can knock out both in an hour, it's not hard. Now all you got to do is find an "honest" wrench turner who won't tell you otherwise!!!!!
Old Sep 17, 2011 | 07:32 PM
chrisdagge's Avatar
E500
ok so i didnt do to bad i bought it 2 days ago with 53000 miles loaded for 14800, im 17 and i have hopeing it wasent going to be another 2k to fix. but i can watch the whole motor move about 2-3 inches when its in gear if i hold the break and hit the gas alittle. ive rebuilt a few small motors and serviced a few trucks. on a level of 1 to 10 how hard is this job
Old Sep 18, 2011 | 12:04 AM
irondad's Avatar
W205, X253, C190, W213,
PLEASE find your shift key
Old Sep 18, 2011 | 12:40 PM
chrisdagge's Avatar
E500
Is that how you answer QUESTIONS?
i thought this was a MB form not english class
Old Sep 18, 2011 | 01:32 PM
Barry45RPM's Avatar
2015 ML 350
forum
Old Sep 18, 2011 | 02:52 PM
JDM_SXE-10's Avatar
2003 E500
I have been experiencing some vibration and took it in yesterday. The told me that it is the motor mount also and they said that they usually do it in pairs. I was told by my mechanic that parts and labor will be $400. This sounds like a reasonable price, but maybe someone can confirm this.
Old Aug 29, 2014 | 07:16 PM
spinn's Avatar
2004 E500
gonna cost me $750 to do all 3 (motor and tranny mounts). I guess inflation? :/
Old Aug 29, 2014 | 09:11 PM
dewana421's Avatar
E320 2004 model Silver sedan
I just replaced my two motor mounts last week...I got quotes for $400 labor to replace the motor mounts but i decided to take on the challenge and was successful. i had replaced my transmission mount few months ago and posted a video on the transmission mounts. that one is a piece of cake. however motor mount can take some time. its not too hard of a job if you know your tools and have someone to help. it was a little harder for me because i was doing it by my self. MAKE SURE YOU REPLACE BOTH MOTOR MOUNTS!!! Don't make the mistake of replacing one or else you will regret it...if one failed the other one is not too far behind..
you will need to remove your exhaust in order to get to the motor mounts.
you will need a good big hydraulic jack to lift your engine. all the work needs to be done from underneath the car.
on a scale of 1-10 as 10 being the hardest, i would scale it as 4.
After replacing the engine mount it made a HELL OF A DIFFERENCE in the ride. its like driving a new car off the showroom.
Old Sep 1, 2014 | 03:07 PM
JDM_SXE-10's Avatar
2003 E500
I have been going to my independent mechanic for years so he has always taken care of me. I just moved to Northern Cali so I will miss him because now I need to find someone just as good and honest.
Old Sep 1, 2014 | 07:16 PM
MercFiveHundred's Avatar
2014 E550; 2003 E500
You didn't need to remove the exhaust.
Old Sep 1, 2014 | 08:24 PM
dewana421's Avatar
There is no way that you can do this job without removing the exhaust. trust me. i did the job and did lots of research before doing it and its a fact.
but mine is a 2004 E320 base and i think its differs from CDI. not too sure about E500.
Old Sep 2, 2014 | 09:19 AM
vettdvr's Avatar
03 E500 and Corvette
My E500 had to have the manifold pulled also the top bolt can't be reached with the manifold in place.
Old Sep 2, 2014 | 10:26 AM
BagMan's Avatar
E55, E320 CDI , CLA250, Jag XJ Supersport
I was able to do my CDI without taking anything off. Not sure about the other cars.
I couldn't have done it without the Mercedes motor mount tool: http://www.ebay.com/itm/Mercedes-Engine-Motor-Mount-Wrench-Tool-16mm-and-17mm-/371015605249?hash=item566240dc01&item=371015605249&pt=Motors_Automotive_Tools&vxp=mtr
Old Sep 3, 2014 | 10:17 PM
Not extensive enough. I researched too and found it can be removed via dropping the power steering rack plate mount. Just because you didn't do it doesn't mean it can't be done.
Old Sep 4, 2014 | 09:09 AM
vettdvr's Avatar
Ever wonder why so many Mercedes motor/transmission mounts fail when other brands dont' fail at such a high rate.? In 50 yrs of driving I only replaced mounts in 2 cars. One was a race car the other the Mercedes.
Old Sep 4, 2014 | 04:26 PM
dewana421's Avatar
lol so you are removing one thing or the other..samething... My point is there is no way you can do it without removing something out of the way. On CDI I heard it is possible but not on others.
Old Sep 4, 2014 | 08:31 PM
No, your point was you had to remove the exhaust. Nice try.
Old Sep 7, 2014 | 10:11 AM
dewana421's Avatar
lol really ? How old are you
Old Sep 7, 2014 | 10:47 AM
sgaar's Avatar
'06 E500, '99 ML430 and '07 SL65
You do not have to remove the exhaust. You only need to disconnect the exhaust from the manifold so you can move the exhaust up. That will allow you to pull the old mount backwards out and get the new one in.
As for the top bolt, you can reach that with a wrench. No need to remove the steering rack or the exhaust manifold. Use the KISS principle here....makes life much easier.
Old Sep 7, 2014 | 11:07 AM
vettdvr's Avatar
Thanks I didn't realize the V8 had that much room up front.
