E-Class (W211) 2003-2009
My first mod of 2012.. E550 No Smoking Edition...
Old Jan 3, 2012 | 07:01 PM
MB4tronic's Avatar
2008 E550
While digging through the forums I came across a user who posted the plastic mat to remove the ashtray and put in the black plastic liner.
Nice little upgrade for $5 if you will never ever use the ashtray..
Tomorrow will be doing the AMG accelerator pedal install and Sprint Booster V.1 install (snagged the one unsold on ebay for under a bill, figured it was worth trying from all the feedback, see how it works with the OEtuning tune)..
Old Jan 3, 2012 | 07:44 PM
Craftysince86's Avatar
W211
damn i have one of those mats in my glove box was trying to figure out what the hell it was for!
Old Jan 3, 2012 | 08:41 PM
Shawnw's Avatar
2011 E350 Cab, 2010 B200
I'd like to get to of those. Where did you get it? Thanks
Old Jan 3, 2012 | 09:04 PM
hyperion667's Avatar
2012 CLS63
wow you got a V1 for under 100? not too shabby
Old Jan 3, 2012 | 09:46 PM
50ae's Avatar
2005 E320 CDI, 2007 GL 450
I've been wanting one of those mats myself. I took the ashtray out anyway and threw it in the trunk as I have no need for it.
Old Jan 3, 2012 | 11:02 PM
MB4tronic's Avatar
2008 E550
Yep. Where is the 10mm bolt? under the black cap? I've been trying to figure it out.. I keep reading its a 2mn install, but can't find the bolt on E class from the C class instructions..
Also what happens when the accelerator goes all the way down and that button is pressed? does it do anything?
And when I install the pedal? should I remove the cover and just use the new cover, or install the whole assembly I got with the curver lower black piece? it seems from the instructions, I should just take the alum piece, slip it off, WD40 it up and slip it over the old piece.
Old Jan 4, 2012 | 08:10 AM
delviacv2's Avatar
2005 E320 CDI
The 10 mm nut is under this little plastic cover once u remove it the whole pedal comes out, just plug the SB in between the pedal and the car's wiring harness it should take about 2 minutes at the most.
Where did you get the little black mat to put in place of the ash tray?
Old Jan 4, 2012 | 08:36 AM
jimbo1763's Avatar
2007 E350 Sedan
I think that is the kickdown button.
https://mbworld.org/forums/e-class-w...gas-pedal.html
Old Jan 4, 2012 | 10:59 AM
MVD's Avatar
MVD
2009 E550 w P1, Flint Black
+1 Where to order? dave
Old Jan 4, 2012 | 11:37 AM
XLR82XS's Avatar
2006 E500 4matic wagon
Ditto. I assume dealer as it is form fit and OEM looking.
Old Jan 4, 2012 | 09:38 PM
MB4tronic's Avatar
2008 E550
OEM part, anywhere really?
2116830051Lining 2003 - 20091$5.63
