E-Class (W211) 2003-2009
The dreaded M272 Balance Shaft
Old Dec 27, 2017 | 01:00 PM
  #476
Shack1's Avatar
06 E350
Originally Posted by rpdeleon
134k roughly
Well that is well over the settlement mileage amount, I think they helped me out since I only had 44700 miles.
What did you pay for the car?
Old Mar 1, 2018 | 06:22 AM
  #477
naghtan's Avatar
w211, W201
I was getting code P0025, few months ago fixed just change the solenoid... but few days it came back, P0025, and after change the solenoid( again) no appear P0020 Could be the Hall position sensor? or My engine it have the issue?
WDB2110561B171180
I am very worried...
Thanks!
Old Mar 1, 2018 | 02:55 PM
  #478
Shack1's Avatar
06 E350
WDB2110561B171180
Thanks!
Mine had code P006 and P007 balance shaft worn badly at 44700 miles
Old Mar 1, 2018 | 03:09 PM
  #479
jimbo1763's Avatar
2007 E350 Sedan
WDB2110561B171180
Thanks!
naghtan, based on the VIN decoder I used, your engine number comes up as 272964 30 638096. Please check me on that, but if accurate your engine is past the affected range of engine numbers, which goes up to 30 468993 (last eight digits).
Old Mar 1, 2018 | 03:42 PM
  #480
konigstiger's Avatar
'71 Pinto
My engine it have the issue? WDB2110561B171180
Not affected by balance shaft.
File Type: pdf
Old Mar 1, 2018 | 05:53 PM
  #481
naghtan's Avatar
w211, W201
Thanks to everybody! Before I bought it at second hand, 3 years ago, I check the VIN code... and I believe it not have that kind of problems... but now with the P002x errors I start to be very worried... and now with the P0020 it is hard to find info about that error on M272... I thought it could be Hall sensor, but error sensor code ends at P0019... ( In some places I read that in one C class that kind of problems was by the alternator... I will try... or perhaps any other sensor like detonation of sparks? or temperature ? I have Wiss and Anra installed at home, but I cant look for DTC codes... It is any way to check it? Perhaps it is time to update my OBD2 adapter... ¿Any recommend of good OBD2 adapter with bluetooth to use with android for Mercedes Cars?
thanks!
Old Mar 2, 2018 | 06:14 PM
  #482
lnvonline's Avatar
ML350
I have a 2007 ML350. Purchased it just passed the extended warranty expired. Ended up getting the codes popped up. Now i'm stuck doing the work myself. (the dealers nor MB USA will not lift a finger to help)
I'm at the point of removing the shaft but, realized i should change the chain as well.
Can't seem to get the Guide Rail Pins out.
anyone out there know how much force is needed to "slide-hammer" them out?
thanks,
Old Mar 3, 2018 | 09:27 AM
  #483
kjb55's Avatar
2025 AMG E 53; 2018 GLC300 4Matic; 2003 360 Modena
I recommend using a bolt insert against a plate that pulls the rail guide pin out rather than a slide hammer. Kits are cheap- but you can fabricate it with pieces from a hardware store for a few bucks.
Old Mar 4, 2018 | 04:00 PM
  #484
toxoscar's Avatar
2006 c280 4matic m272
206 c280 4matic engine swap
Can anyone here shed some light on an engine swap? I have a 2006 C280 4matic with the dreaded m272 balance shaft issue. The car has 83k on it...still runs ok but is getting noisy and cam codes stay on. Will a 3.0 engine from a 2009 C300 work in my car. They are plentiful in my area and reasonably cheap. They appear to be identical, but I'm hoping someone here with more knowledge than me can help.
Any info would be greatly appreciated.
Steve Prescott
2006 C280 w203 4 matic
2003 w163 ML350
Old Jul 6, 2018 | 05:50 PM
  #485
og style's Avatar
ML320
Does anyone know what percentage of these motors end up needing repaired?
Old Jul 6, 2018 | 05:57 PM
  #486
Shack1's Avatar
06 E350
I WOULD BET 99% unless the shafts came from different manufacturers.
Mine have codes 0016,0017 at 44700 miles and had had three oil changes with Mobile1 0-40, so it was NOT a lack of maintenance.
Old Jul 7, 2018 | 04:38 PM
  #487
og style's Avatar
ML320
I call a Mercedes dealer and they told me that is not all that common.
Old Jul 7, 2018 | 05:43 PM
  #488
Shack1's Avatar
06 E350
Oh then by all means everyone go out and buy a CHEAP USED 2006 MERCEDES since the balance shaft issue is such a rare occurrence. LMAO
Old Jul 8, 2018 | 05:16 PM
  #489
95viper's Avatar
2007 cls550
I just did this idler gear / sprocket replacement on a 07 CLS550. A couple of points.
- Engine doesn’t have to come out on a V8 but you would be crazy not to. I was. You end up having to disconnect everything except 4 bolts and you will probably spend 20 extra hours if not.
- Engine has to be pulled in a V6. You have to get to the back of the engine.
- The V8 gear and the V6 balance shaft have teeth The are not hardened. The chain eats the teeth. These 10% affected claims are nonsense. Good luck proving that unless there is a hidden document that alternate suppliers provided hardened gears.
- The rear camshaft plugs leak and are a cheap and easy fix.
- The front camshaft sensor O rings can leak and are an easy replacement.
- The front camshaft adjusters leak/break and are a cheap and relatively easy fix. One is a bit of a pain because the oil housing has to come off but no big deal.
- The vacuum operated lever on front of intake manifold can break and is an easy fix if the manifold is off.
That’s everything I can think of right now.
Old Jul 15, 2018 | 02:59 PM
  #490
kerryroberts's Avatar
E350
How can I know if 2006 E350 balance shaft was fixed by PO?
How can I know if the previous owner(s) had the balance shaft issue fixed? The car has been repossessed by a bank so I don't have any access to the previous owner or service records. It currently has error codes of P0016 and P0017. Mileage almost 200,000. Starts easily and idles smooth. Thanks so much.
Old Jul 15, 2018 | 03:50 PM
  #491
jimbo1763's Avatar
2007 E350 Sedan
If the repair has been done, it should not show the codes, as surely the repair mechanic would have cleared them. Those codes indicate possible balance shaft issues.
There is a YouTube video here that shows how to check visually. However, the fact that the codes show is a real issue. The cost of repair on the balance shaft is high-maybe the former owner just decided to let it go back to the bank?
Old Jul 15, 2018 | 04:22 PM
  #492
og style's Avatar
ML320
Do you know what the YouTube video is called?
Old Jul 15, 2018 | 04:31 PM
  #493
jimbo1763's Avatar
2007 E350 Sedan
Try to disregard the techno-music!
This won't really say that the repair has been done, but it should indicate whether there is a balance shaft problem. The teeth on the defective balance shaft sprocket get worn, and that throws off the positioning of the timing chain, as I understand it, thus throwing the code.
The cost of the repair is usually over $5000. That often essentially totals the car. I had to have the repair on my 2007 E350. My wife has a 2006 E350, but relatively low miles, so no issue has popped up yet. Keeping fingers crossed. We are seeing more and more of these at higher mileage.
Old Jul 15, 2018 | 06:27 PM
  #494
cetialpha5's Avatar
The parts aren't that expensive a little over $400, but you have to remove the engine in order to replace it so a lot of it is just labor. There are reports of indy shops doing it for around 3k but there are also reports of indy shops doing it and then it doesn't quite run right afterwards. If the mileage is high, I'd also think about replacing the intake manifold too as those are known to go.
https://www.fcpeuro.com/products/mer...des-2720300613
Old Jul 15, 2018 | 06:45 PM
  #495
jimbo1763's Avatar
2007 E350 Sedan
+1.
I don't know what the purchase price being asked is, but if the balance shaft needs replacing, there may not be a lot of value there on a 2006. Be really careful.
Old Jul 17, 2018 | 04:47 PM
  #496
og style's Avatar
ML320
Originally Posted by jimbo1763
https://www.youtube.com/watch?reload=9&v=XXQArmxXsnM
Thanks for the video. Is there anything that I can look for to tell if it has been worked on before?
Old Jul 17, 2018 | 05:15 PM
  #497
95viper's Avatar
2007 cls550
The front camshaft covers might have black RTV oozing out depending on how careful they were. Then again the factory wasn’t perfect.
I guess you could remove the chain adjuster and see if it is the old or new style but that is $100 wasted and doesn’t prove anything.
I wonder if the markings on the cam gear covers changed over the years? This would be viewable through the holes after removing the cam sensors. Again doesn’t prove the balance shaft was replaced but still.
The inspection scope is the only way.
Old Jul 17, 2018 | 05:22 PM
  #498
jimbo1763's Avatar
2007 E350 Sedan
Other than an invoice or service record, not that I am aware of.
The balance shaft repair requires removal of the engine. The repair parts are not that much, but the labor cost is huge.
It is possible, although not likely, that the codes never got cleared. If they are cleared and the problem is still there, they should come back, although that may take some time. The fact that the codes are still there makes me think that the repair has never been done.
This may not be the car for you, unless the bank is willing to pay for the repair. Some people have been replacing the engine with a newer one (past the effected range of the balance shaft matter), as that may actually be cheaper than the repair.
This is an issue that anyone looking at this car will face. It is not at all unreasonable to tell the bank about it and ask what it will do. Someone is going to have to fix the problem, or prove to your satisfaction that there isn't one. You should not bear the risk, nor should you bear the expense.
We heard that only something like 25% of the affected cars would end up with the problem, although no one really knows for sure. Over time, and with higher mileage, we are seeing more of this popping up beyond the mileage range we would have expected (65K to maybe 100K). Like some others here, I am beginning to wonder if all of the cars in the affected range will ultimately have the issue arise.
Old Jul 17, 2018 | 05:30 PM
  #499
95viper's Avatar
2007 cls550
The only way that this problem affects a percent of the cars such as 10-25% is if the parts were correctly sourced as hardened and the supplier(s) supplied both hardened and not.
In theory I guess that could be true but it is more realistic that it was sourced incorrectly and changed to hardened parts after the problem was found.
Old Jul 17, 2018 | 05:31 PM
  #500
Shack1's Avatar
06 E350
MB should have a record of the work, also there is this site that lets you check main history if you sign up and just say its your car you want to add.
Been though this on my 06 E350 at 44700 miles, MB covered 15% total out of my pocket $5400. No indy would touch the job.
https://www.mycarfax.com/garage
WELL doesn't tell you much, here is the details from my balance shaft repair.
Mercedes - Benz of TemeculaServices Performed
  • Vehicle serviced
