E-Class (W211) 2003-2009
Old Jun 17, 2015, 02:51 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Electrical System
Print Wikipost
Replace starter on E500 V8?
Old Apr 16, 2012 | 08:48 AM
vettdvr's Avatar
03 E500 and Corvette
Anyone replace a starter? Any traps? photos? Best place to buy. Exhaust have to come out of the way? Tools?
Mine sounds like starter drive with loud screech when starting (not gear grinding). 99% sure dry starter drive and will go out soon. Thought I would start preworking replacement vs rebuilding at starter shop.
Old Apr 17, 2012 | 05:15 PM
vettdvr's Avatar
After 156 hits on this question it is a surprise no one has had a starter problem.
Old Apr 17, 2012 | 11:47 PM
AMGAffalterbach's Avatar
2014 BMW M235i
I truly wish I could help but to be honest I take my car to the dealer for any work that needs to be done on it - yes I pay out the rear but that's just my way of making sure I don't screw anything up.
"Locate the starter by tracing the positive battery cable, which splits and travels to the alternator and starter motor. You will know that the starter needs replacing if your battery is still working, but you only hear a "whirring" and a click whenever you turn your ignition key. Disconnect the negative battery cable and unhook the electrical connection leading to the starter. Use a socket wrench to remove the two mounting bolts for the starter and unscrew the brass nut securing the positive battery cable feed. Insert a new starter into the Mercedes E Class 320."
This is the only sort of step by step instruction I have seen thus far but mind you it is for the E320 - probably the same though if it is actually referring to a W211.
Old Apr 18, 2012 | 06:31 AM
vettdvr's Avatar
Thanks I will figure it out and photo the work. If this is the first someone has to be the first to change one out. Just hope the Ex. pipes dont' have to be lowered. I really don't like doing exhaust work.
Old Apr 18, 2012 | 12:27 PM
DanG2's Avatar
04 E500
Star Service CD says:
1. Disconnect ground cable from battery.
2. Detach lower engine compartment paneling.
3. Dismount electrical lines.
4. Dismount right engine mount from engine support. (Unscrew bolt at engine mount, lightly raise engine and place engine mount to the side.)
5. Unscrew bolts.
6. Take out starter to the side.
7. Check ring gear on the drive plate for wear and damage.
8. Install in reverse order.
9. Perform function check.
10. Render electrical system operational. (i.e.,normalize everything)
11. Read diagnostic trouble code memory and erase.
Looks like you're in the clear on the exhaust. Connection nut torques for circuits 30 and 50 are 14 and 6 Nm, respectively (if you care; I didn't look up the circuits, figure it should be obvious), and torque for the starter bolts is 42 Nm. Looks pretty simple, but you need more detail on any of it let me know.
Old May 24, 2012 | 10:06 AM
vettdvr's Avatar
5. Unscrew bolts.
Now my actual hands on update.
1. Disconnect ground cable from battery. (no problem easy)
2. Detach lower engine compartment paneling. (no problem easy)
3. Dismount electrical lines. (no problem easy)
4. Dismount right engine mount from engine support. (Unscrew bolt at engine mount, lightly raise engine and place engine mount to the side.) (no problem easy) BUT There is a bolt on the top of the engine mount to allow the top to move. This bolt I could not reach. Note the steps in the procedure to the right on the cd about remove mount. The right Exhaust and manifold must be removed to remove the engine mount.
5. Unscrew bolts. Could not get to this step as I could not remove the engine mount due to the top bolt securing the mount in place and the mount would not move with the engine jacked.
Never happened. I am not structured in my shop to pull exhaust.
So now the answer to my origional question does the exhaust have to be removed to get the starter out. YES!
Old May 24, 2012 | 02:49 PM
Flash Gordon's Avatar
2003 E500, 2004 G35X
Man, 1/2 year ago I replace my starter in the G35, and it took me 3 hours to remove many things and very hard to reach to the bolts on the starter, and a tiny little place to work the starter loose and to put the new one in. Fortunately, I was on my back all the time.
You have to remove the exhaust to reach the starter is more than poor engineering by MB. I guess it's either the stealer or access to a lift.
Old May 24, 2012 | 04:23 PM
DanG2's Avatar
04 E500
I have to apologize, it's me who needs the head knocking. Obviously I have more to learn about reading Mercedes AR's.
I expected any cross-reference to another AR at the "lightly raise engine" instruction would be on the same line as the instruction. That's how the others are, and there was nothing on that line. Instead I now find that there is a reference to an AR on removing engine mounts, and in that AR it does indicate the front exhaust has to be removed. Unfortunately, it's two lines below the "lightly raise engine" instruction and I simply missed it. It's not the way I would have done it, but I can't use that as an excuse.
I guess the only good thing is I now know more about what I don't know so I can avoid making that mistake again. For now, though, all I can do is apologize - profusely.
Old May 24, 2012 | 04:36 PM
vettdvr's Avatar
No apology needed and no offense taken. I have been doing this type of work over 45 years and my motto,,,"It's never as easy as it looks". I wasn't surprised to find the manifold and exhaust have to come out.
I know how to do it but without a lift I won't pull that stuff as I did 40 yrs ago on my 58 Ford.
Hopefully we all now know about this issue and someone will find an easier way to get it out. Being over 65 when I run into this either I will take it to shop or go car shopping. The MB is 120,000 and still going but I have no heartburn with a new car and warranty. It was a MB design issue.
