Rear Brakes Sensor
The breakdown of the quote is $126.00 for labor, $87.00 for the brake pads, $7.25 for sensor, and $15.42 in taxes for a total of $235.67. So its a little less than the $250.00. What do you think would be a fair price for this job?
Thank you.
If you have only 5% pad left, then it should be pretty easy to see with the wheel off that there's only a few mm of pad material left on the pad backing plates. I have no idea why the sensors have not kicked in yet to tell you.
IF you have the sensor and no + in the FSS under the service you probably don't need new pads.
