symptoms of airmatic strut failure
On my 2004 E500 the right front airmatic strut failed at 66k mi and the left one failed recently at 91k mi. Just before 66k mi, I'd noticed that there was quite a bit of oil leak at the bottom of the right front strut, and very small amount of oil on the left strut. When I did the tire rotation at 90k mi, the oil leak on the left strut got worse, but I didn't want to replace it that time because of the high cost. Sure enough, it blew up at 91k mi.
If you see some very small oil leak at these struts, you probably can drive for a while (~10k mi?) before they blow up. Well, if the bottom of these struts are coated with a film of oil, you should replace them ASAP. I've read that if oil is leaking out of the pump, which is built inside the airmatic strut, the pump can over heat during normal operation and will eventually fail.
And it is handled as a regular maintenance item. Right now after 50K miles or so one day you are going to come to a car that can't be driven. God forbid if you are not in a good area or have gone camping and far away from cell phone range you are screwed. As much as I like it when it is working, it is very bad design.
They should have built an "emergency" limp mode that lets you drive about 50 miles or so...
07 E550 - Drove home Sunday night & kept hearing a farting noise when at red lights...came out in the morning & car was dropped down on that wheel. Started the car got the farting noise & no lift. No warning ever appeared on DIC.
Jack
