E-Class (W211) 2003-2009
AMG look for 03 e200k
Old Oct 22, 2012 | 11:12 AM
zelly's Avatar
Mercedes e200 w210
Yo guys, im maybe buying this car next weekend. http://www.finn.no/finn/car/used/obj...1695159491.jpg
It says the colour is black and the paint is Metallic . Is it rally black then, noe blue-ish? Arent there only two true black colour from Mercedes, obsidian black and another? Also it is elegance versjon. Will it look bad with only an amg frontbumper on it? Can someone link a pic of a w211 with only an amg frontbumper and rest stock? If it looks bad ill have to buy a whole package then. It doesnt have parktronic so i will have to get without holes. Does the 03-06 amg use another grill aswell? Same as avantgard ? Should i get oem or replica bumpers?
Alot of questions i know, hope you could help. I want atleast the front to be 100% amg look with painted grill. This will be my first ever car. Thanks
Old Oct 22, 2012 | 12:56 PM
Craftysince86's Avatar
W211
paint code is 040
amg grill is not different, in the states the inserts are black and the outside chrome. so idk if the one on that car was painted all black or that's how they come?
Old Oct 22, 2012 | 01:41 PM
zelly's Avatar
Mercedes e200 w210
Originally Posted by Craftysince86
paint code is 040
I think the owner did it he said, same with the exhaust. So the colour is nice? How did you check it, vin nr?
Old Oct 24, 2012 | 05:13 PM
zelly's Avatar
Mercedes e200 w210
Bump. Anyone link me amg bumper(s) on ebay? Have to ship to norway
Old Oct 24, 2012 | 05:27 PM
Fictivision's Avatar
2005 E200k and 2014 E300CDI HYBRID
Hei zelly,det ser ut som bilen i annonsen har en elegance grill som er malt i svart.
Også en AMG bakfanger ville ikke passet på den bilen med de eksospottene da de er ikke originale fra Mercedes,så jeg ville helst beholdt den bakfangeren sånn som den er.
Hvis du har penger da er det bare å kjøpe AMG frontfanger,avantguard grill og noen finere felger da de på bildene ser helt grusomt ut på bilen.
Old Oct 24, 2012 | 05:53 PM
zelly's Avatar
Mercedes e200 w210
Takker for svaret. Ja felgene er fæle og 20 tommere. Heldigvis var dekkene elendig så får nok pruta ned prisen og da blir det nye felger og dekk til våren . Amg framfanger er et must for meg iallfall, kan leve med resten hvis det ikke kommer til å se ut som en plog:p har lyst på amg felger, men tar det littsenere . Burde jeg kjøpe original amg fanger, eller sånn kopi greier? Vet du om en norsk side? Og hva er det største norskemMercedes forume , mercefreaken?
Edit; blir ****a pga jeg bruker mobil, er uten pc i en uke
Old Oct 24, 2012 | 07:01 PM
Det er flere nettsider som selger mercedes styling.Du har den norske autoroyal.no så den svenske mbsca.se.Autoroyal selger originale rangere men er ganske dyrt,på mbsca går an å kjøpe uoriginale for noen tusenlapper.
Bra norsk forum for mercedes ved siden av mercefreaken er mbentusiastklubb.no,er medlem der selv.
Old Oct 24, 2012 | 09:17 PM
NorseWagon's Avatar
2019 E-450 Wagon
Fine biler, men vedlikeholdet kan være dyrt, spesielt på merkeverskted.
Vet ikke om denne bilen har luftdempere, men de er svindyre og ikke særlig robuste. Har noen skrekkhistorier på lager fra min 2004 E-500, men den har vært under garanti så jeg har sluppet de dyreste reprasjonene.
Lykke til.
Old Oct 24, 2012 | 09:28 PM
zelly's Avatar
Mercedes e200 w210
Lykke til.
Er det ikke bare stasjonsvogn og s-klasse det er airmatic på? Denne bilensskal være veldig velholdt, ringt og snakket med alle tidligere eiere.
Old Oct 24, 2012 | 09:36 PM
NorseWagon's Avatar
2019 E-450 Wagon
Hmm ikke sikker, trodde det var airmatic på personbilene også, men kanskje det var en valgmulighet og ikke standard?
Min bil har gått ut på garantien og det gjør meg nervøs, har 4 hjulstrekk og skulle automatkassa med alt det utstyret ryke så koster det over halparten av bruktverdien på bilen å få det reparert. Billigere å få seg noe nyere, eller gifte seg med Mercedesmekaniker..
Old Oct 25, 2012 | 02:02 AM
zelly's Avatar
Mercedes e200 w210
True :p bilen skal på NAF test før kjøp just in case. Føler meg ganske trygg egentlig, bare å finne utet bbillig sted å kjøpe AMG frontfanger fra.
Old Oct 25, 2012 | 06:00 AM
Min E200 kompressor har airmatic,heldigvis røk den ene demperen bak mens bilen fortass hadde bruktbil garantien så jeg fikk begge bak byttet Koster ca 10000kr per demper inkludert arbeid å bytte.
Old Oct 25, 2012 | 08:09 AM
zelly's Avatar
Mercedes e200 w210
Fornøyd med motoren ? Hørt at den er veldig fin mtp ytelse og forbruk.
Old Oct 25, 2012 | 08:18 AM
Veldig fornøyd,motoren liker høye omdreininger og har grei lyd også,det jeg liker best er hvor stille den er når bilen står i ro.
Old Oct 25, 2012 | 08:54 AM
zelly's Avatar
Mercedes e200 w210
Høres bra ut. Finner bare originale framfangere og de blir for dyre :s
Old Oct 25, 2012 | 11:48 AM
Sjekk denne linken.
http://www.mbscashopen.se/sv/e-klass...t-med-pdc.html
Old Oct 25, 2012 | 02:16 PM
zelly's Avatar
Mercedes e200 w210
Takk for linken. PDC er det parkeringssensorer? Liker egentlig ikke sideventene som e63 amg har, hadde tenkt på en e55 look. Men ser ut som man slipper å ta ut slik at det ikke blir åpning i venten? Og hva er dimlys? Er så dårlig på lys :p
Old Oct 25, 2012 | 03:13 PM
PDC er parkeringsensor på svensk,men du kan velge om du vil ha med eller uten.Når det gjelder sidevents da må du ta kontakt med butikken på mail og spørre om dem har en vanlig e55 fanger,ellers er de prisene i svenske kroner,koster vesentlig mindre i norske kroner.
Old Oct 25, 2012 | 06:59 PM
NorseWagon's Avatar
2019 E-450 Wagon
Ja, det var vel det samme eller en smule dyrere her i USA: Det gakk visst på 4500 daler for de 2 front demperene men det var mye styr, de måtte bestilles fra Tyskland og det tok et par uker, osv, osv.
Zelly:
Skjønner du skal skifte støtfangere så bilen skal se ut som noe den ikke er: AMG:
Det er jo som å smøre lebestift på en gris, den blir ikke AMG uansett..
Anbefaler heller å bruke pengene på noe brukbart isteden, nye dekk og bremser, etc, kosmetikk er bortkastet, men, men bare min mening og den spurte du ikke om så da så.
Søk litt på det emne om å jåle til en W211 til å se ut som AMG her på forumet så får du mange treff.
Ser du er i Bodø? En annen kar på dette forumet har en W211 stasjonsvogn i Bodø, han heter Norseman, Widerømekaniker såvidt jeg husker.
Old Oct 25, 2012 | 08:36 PM
zelly's Avatar
Mercedes e200 w210
Ja, det var vel det samme eller en smule dyrere her i USA: Det gakk visst på 4500 daler for de 2 front demperene men det var mye styr, de måtte bestilles fra Tyskland og ikke et par uker, osv, osv.
Zelly:
Har ingen intensjon av å lage en fake amg og sette på emblem og sånt. Jeg vil få bilen til å se finere ut og mer sportslig. AMG frontfanger får bilen til å se fantastisk mye bedre ut imo. Ville ikke kalt det jåleri studerer i bodø for tiden ja
Old Oct 30, 2012 | 03:33 PM
zelly's Avatar
Mercedes e200 w210
bump. Is "black metallic" paintcode 040? The owner said when the car was clean and polished it could seem green-ish. Is it true black or? Ill take the amg bumpers on a norwegian site
Old Oct 30, 2012 | 03:40 PM
W211
040 does not have pearl in it
Old Oct 30, 2012 | 04:09 PM
zelly's Avatar
Mercedes e200 w210
thats good, i like true black. btw how did you find the paintcode first of all? Was it because it said black metallic and you know that the paintcode is 040?
