Considering a used 2003 E320 with a interesting issue
The engine has a huge delay in reeving. The throttle behaves very unresponsive and lagging. For example the car sits in park and with the engine running while on the accelerator (all the way) after 2 to 3 seconds the engine starts to accelerate in slow increments and this also persists while driving. Car idles and drives fine when its going and the engine pulls quite well but it is a bit of a concern especially when taking left turns with the opposing traffic. It feels as you would just barely step on the accelerator to only incense the RPM's slowly to red line.
I'm hoping this is a small reprogramming fix with the accelerator and the drive by wire system and not a major engine problem.
I've also noticed intermediate ticking coming from the front of the right valve cover, probably just a sticky lifter. Could this be a potential problem without taking the valve cover off and looking lifter wear? Is the ticking common or are these engines known for low oil pressures and lifter wear?
Thanks in advance.
I have an 03 and knew I was going to have issues, so I invested in a warentee, Cost 2200 dollars and they have paid out 13,400 dollars in repairs. I purchased the car for 14 or so.
So buy it sure, but a make sure its in perfect shape, and get a warentee, there at the age where things will break and wear, and need replacement.
Mine has 83K miles
https://mbworld.org/forums/e-class-w...-included.html
As for the the throttle response, the throttle position sensor may be part of the problem. Get an inspection before you buy. If it is slow to respond even in Park, at least you know it is less likely to be the transmission.
Its less likely to be a transmission problem, it might be a TPS sensor but there are no indicators to confirm that other than the symptom i described. I realize i will need to take the car into the shop but i was hoping i could gather some info and use it to my advantage with the dealer upfront as opposed to having some skin into it (payed 125 for an inspection) in which case the dealer has the upper hand.
The 5.7 hemi is very smooth about 40 hp more than the E500 and 40# more torque. Zero defects after 3 weeks. The MB had been back twice by this time. Wife really likes the car and have 6/72 warranty so I have no plans to work on it.
I'm still around and will still help others driving MB. I just won't be driving one. Once an Engineer always one.
I'm still researching all the pros and cons about the S500 to see what I'm really getting into besides an expensive air ride.
@jquiroz There are many issues with the 03 models, just look at VettDvr's car. The issues include the SBC braking system - the pump can fail and cause brake failure or extremely reduced braking, there have been issues with some of the cheap wiring harnesses they have used, I can name a few members that have had some BCM issues or parasitic drains on their battery due to the Chinese-built electronics (or other failures), they had problems with glycol leaking into the transmission fluid and ruining several components, a lot of things to list here. Just look for some of vettdvr's previous posts and his repair list it was very extensive. A lot of these issues were eliminated by the facelift W211 but 03 was not a good year in general. Not to say that your car will experience these issues, however, these are just a plethora of complaints from early W211 owners whereas I am sure some are (and will be) fine. So it's no guarantee of your cars future failure or good performance.
I have a late 2003-built W211 4matic sedan with 129K miles. I have owned the current one for a year. I owned an almost identical one a few years ago, too.
I'm happy.
I replaced all disks and pads myself. They were overdue for it. Your car has the SBC brake system. It has it's challenges and you should anticipate the potential, but not the certainty, that it will need replacement. Mine works fine, but I can understand the views of those for whom that has not always been true.
I've replaced two side marker lights myself. Easy.
It's had two oil changes and air filters for the engine and the cabin air. All by choice and easy to do.
I had all transmission, filter, diff and transfer case fluids replaced y an Indie. That solved a surging problem at low speed due to insufficient trans fluid and was good maintenance anyway. If your transmission had the glycol problem, I think it would have evidenced itself by now.
I had a Check Engine Light. It was self-induced by carelessness when I changed the spark plugs and wires. I knocked loose a vacuum pipe and took months to realize exactly what I'd done but it was 3 seconds to fix once I found it hanging loose behind the headlight. I'd been looking in all the wrong places.
Your car probably does not have the airmatic suspension. That makes ownership of an E320 a little easier than owning an E500. That said, you will need to expect ball-joint replacements and some front-end work from time to time.
A car of the age of yours may need battery replacement at some point, depending on the actions taken by previous owners. I suggest you learn where the front battery is and how easy it is to replace and also learn where the rear battery is. And learn how to check the voltage of each. That way you'll know a little of what to do if a problem comes along. The threads on batteries on this forum are way too long to digest when you actually have a problem.
Expect to change the heater valve if your car seem too cool. There's a DIY for it on this forum.
