E-Class (W211) 2003-2009
Old Jun 12, 2015, 06:42 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Interior Guides
Print Wikipost
project (audio 20 aux input installion)
Old Feb 26, 2013 | 09:22 AM
altahhan's Avatar
w211 e220 cdi
My 04 E220 CDI Classic has a standared audio 20 with cd changer (both read cd not mp3) and I want to upgrade my sound system to add Ipod
I searched a lot on this topic and I found that my glove box has the hole for aux but it is closed so I opened it (just push a small piece with me finger)
I searched about an aux input slot and did not find so I need your advice
1-what is the suitable cable AUX CABLE part #,
203 540 61 07
or
211 54 099 910
the glove box after insert the slot will look like this
before it was like this
2-how do I connect the aux cable into the radio because I searched in my car below the glovebox and in the both sides for a wire (I just find one port with two wires black and brown) or I must connect it direct to audio 20 port
3-I press the cdc button for 3 seconds and did not changed to aux INPUT ACTIVE
I am still waiting everybody advice for this complex story
Also I found these wires in the glove box but I think it is for the taxi adapter (my car was a taxi before)
Old Feb 28, 2013 | 06:35 AM
altahhan's Avatar
w211 e220 cdi
Where are the experts???????????????
two days waiting with no replies .....
I have no chance in my life
Old Feb 28, 2013 | 08:11 AM
boardboy330's Avatar
2000 ML320, 2005 E320 CDI
I have no clue, but I am interested too. My Brother recently bought a 2003 with the same HU and I would like to add the AUX to it for him.
Old Feb 28, 2013 | 12:04 PM
jquiroz1969's Avatar
190e 2.6 Sportline
+1 this would be great, as i tried using those fm transmitters aux connectors and it was garbage.
Old Mar 1, 2013 | 04:54 PM
altahhan's Avatar
w211 e220 cdi
It seems that it is impossible as I see
Old Mar 2, 2013 | 08:12 AM
I have a 2005 CDI and I will chase the lead today when I get home. Hopefully there is a model number or port I can ref for you.
Old Mar 18, 2013 | 10:36 AM
voodoo2000's Avatar
2006_W211_E 200 CDI
aux cable to audio20.
Dear Friend.
I solve this problem this way. I have W211 E200 CDI. model year is 2006. Facelift. And ı have audio20 radio/Cd systme on my car.
You can watch this video how they install aux cable to on Audi20 system. And also i can send some picture too for to see more details. You need only 1 aux cable and one person experience on soldering. And 3-5 dolars for soldering.
I did exactly same this solution on my car and now i listen music from my mp3 player, my phone or my tablet. All sound tom come from 3,5 sound out from my devices. You can listen music and also you can hear your phone calls frome speaker too.
Video on youtube:
Photos:
Advices:
1- before soldering, should to pass your aux cable from a hole of your device back side. Othersel will be crushed between cover and divece. Any hole you can use.
2- If you dont know soldering then find somebody experience. Becasue of soldering points is very small and thinn. I found somebody and they did for me in 3 euro.
3- pictures show to you where you will soldering left and rigt channels on aux cable. But, cable also has a notrcable too. You can solder this notr side to any corner on big shiny metal. (you can see examples on small rectangular window which looking up in second pictures).
4- Before to soldering you have know left and right channel is wihc cable. Then you can soldering to correct point. If you dont have idea then you can connect every cable on your car without installation and you can try cables just to touch to this soldering points. When you sure then solder it.
5- Select a good quality aux cable. I mea resistance and thick. Becasue if you select weak cable then will destroy in shor time becasue of you will move. Then will be difficult to soldering again to same point. Do one time, and do good one. And fix cable to some where. Then when you pull up cable after installation then you dont stress soldering points.
Goodluck.
Ahmet SEVIK / Turkey...
Old Sep 5, 2014 | 07:10 PM
beejAMG's Avatar
W204 C63 AMG, W212 E250 CGI, C207 E250 CGI
to the OP, I know this thread is old but ill take my chances...
mate would you know if there is a plug waiting for this cable somewhere in between the HU and the glove box? I mean so I woudlnt have to remove the HU if ever.
I started a thread about this...
https://mbworld.org/forums/e-class-w...put-cable.html
when i stumbled on yours. i hope you can give me some inputs. cheers!
