E-Class (W211) 2003-2009
Old Jun 15, 2015, 07:05 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Lighting Guides
Print Wikipost
w211 mood lighting bulb change
Old Feb 27, 2013 | 05:55 AM
romanap25's Avatar
w211 280 CDi
Hi everyone. I looked through many posts, but i don't seem to find any information about changing bulbs in the round mood lighting you can see on a picture attached. Mine is very dim and bad looking so i want to change the bulbs. I tried taking it off with a screw driver but i'm afraid to break it as it doesn't want to come off. Anyone got any info on how to change those bulbs?
Old Feb 27, 2013 | 08:45 AM
forcefed4door's Avatar
05 E55, 06 Audi S4
Pretty sure you have to remove it from ceiling and replace those bulbs from the back. There is a DIY on how to remove it
Old Feb 27, 2013 | 09:09 AM
romanap25's Avatar
w211 280 CDi
where can i find it?
thanks
Old Feb 27, 2013 | 09:15 AM
Barry45RPM's Avatar
2015 ML 350
Did you first try to increase the brightness of the mood lighting by using the set up menu?
Old Feb 27, 2013 | 09:25 AM
romanap25's Avatar
w211 280 CDi
yes i did. it's on the highest setting. The rear one is brighter, the front one is really dim.
Old Feb 27, 2013 | 10:15 AM
Craftysince86's Avatar
W211
yup you have to take it down of the the roof to get to the bulbs on the backside..
to do the front you have to take off the rear view mirror, and then there are tabs between the headliner and the console you can depress with a flat and pull it down
Old Feb 27, 2013 | 10:21 AM
romanap25's Avatar
w211 280 CDi
Thanks, now i need to work out how to take off the rear view mirror. I wonder why there are no posts about this.
Old Feb 27, 2013 | 01:48 PM
09W211's Avatar
2009 W211 E350 AMG Sport PKG
there's a plastic piece between the rear view mirror and the dome light assembly. just pop that off, and then take off the plastic cover on the windshield. turn the mirror so that the mirror is facing the door, and just push it towards the door and it will pop off.
when you put it back in, use a strong flathead and compress the spring to seat it back into its original position. going to need a flathead to compress the spring because that spring is retardedly stiff.
Old Feb 28, 2013 | 05:46 AM
romanap25's Avatar
w211 280 CDi
Wow Thanks a lot for the video. i would never figure it out myself. i'll give it a go tonight.
Thanks again
Old Mar 1, 2013 | 12:41 PM
romanap25's Avatar
w211 280 CDi
Right, I managed to take it all apart, but the bulbs are like nothing i've seen before, very small LED and are not removable, same LED as under the buttons. I can't remove them unfortunately, so i guess it will have to stay like this, dim.
Old Mar 1, 2013 | 02:46 PM
05 E55, 06 Audi S4
Wow well thanks for heads up so I don't waste my time trying to fit leds in there haha. Sorry to hear about you dim issue too. My guess is to try and fund a used complete dome assembly.
Old Mar 1, 2013 | 03:35 PM
PewterGreyBenz's Avatar
04 E500 Pewtergrey/ 06 E55 AMG White
There has to be a way rather than buying a completely new assembly.
Old Mar 1, 2013 | 05:30 PM
konigstiger's Avatar
'71 Pinto
http://www.benzworld.org/forums/w211...-lights-2.html
Old Mar 3, 2013 | 03:16 AM
romanap25's Avatar
w211 280 CDi
@konigstiger
Yes you can replace the 2 big lights in the middle with normal led's but i was actually talking about the round yellow light on the outside of the unit, the one that is on when you are driving at night with headlights on. they seem to be very tiny and wired in.
Old Mar 3, 2013 | 08:41 PM
AMGAffalterbach's Avatar
2014 BMW M235i
I just noticed having owned my car since March of 2012 that the interior door handle area is actually lit by a hidden light under the trim. I have no idea how I would replace that if that ever goes out, but it's an incredibly nice touch.
Old Mar 4, 2013 | 05:20 AM
romanap25's Avatar
w211 280 CDi
Yes i have noticed that too. I do prefer however the mood lighting in the new w212 where it goes across the whole dash and doors, looks great.
Old Mar 4, 2013 | 01:26 PM
2014 BMW M235i
Yeah my friend just bought a 2013 SLK250 and it has red accent lighting that (similar to the W212) looks amazing.
Old Mar 4, 2013 | 09:16 PM
frpzxvaa's Avatar
bmw
