E-Class (W211) 2003-2009
Spark plugs replacement for better MPG.
Old Apr 17, 2013 | 08:12 PM
vbnBbnNAng's Avatar
2008 M.Benz E350 Sport
I replaced the original Bosch spark plugs to NGK's and have noticed 3 miles + on highway MPG improvements on 08 E350 Base model. I was used to see 24-25.6 MPG on highway cruising around 70-75 MPH vs now its around 27.4-28.7 MPG.
Old Apr 17, 2013 | 09:26 PM
boardboy330's Avatar
2000 ML320, 2005 E320 CDI
NGK came stock on my ML320. I have used them many times on other vehicles - they are solid choice.
Old Apr 17, 2013 | 09:58 PM
Jlazer's Avatar
Mercedes-Benz GLK 350
Could be that you had a tune up, that's why you're getting better gas mileage. Little sceptical that those particular spark plugs can give such a great improvement. Thanks for the tip, will check it out
Old Apr 17, 2013 | 10:08 PM
ozusa's Avatar
2004 E320 4matic Sedan
How many miles on the old plugs and wires?
Per my subject heading, it would be interesting to know
a) how many miles the old plugs had on them?
b) did you replace the wires at the same time?
Either way, it looks like replacing them has helped, which is great for you.
Old Apr 17, 2013 | 11:24 PM
vbnBbnNAng's Avatar
Hello everyone,
The car has about 63k miles on it.
By replacing the spark plugs the idle has also smoothed out during cold starts. It use to have a lite spotter sound during cold starts making me think it was the EGR????
This model does not have plug wires as it has coils. The good news is this model (08 E350) engine has only 6 spark plugs vs older versions where they had 2 spark plugs per cylinder.
If you go to NGK USA site, there you can pull up your car make and model and it tells you which spark plugs are available.
The NGK spark plugs I used on my car are 4288 Laser Platinum.
Old Apr 21, 2013 | 04:17 PM
vbnBbnNAng's Avatar
Today while driving I noticed the MPG recorded 28.8 and kept up with it and it reached as hi has 29.5. The speed was between 68-77 MPH. This time I took a picture.
I don't recommend you take pics while driving and I did it just when I found an empty/stretch on the highway and 4 empty lanes to my self.
I have gone thru 1 gas tank already since the Spark plugs been changed to NGK.
For Gasoline I use Premium Shell/Exxon and sometimes BP.
All major brand's Unleaded gasoline here in Nashville have 10% Ethanol in them.
I have tried 0% Ethanol but the gain was not that much.
Old Apr 27, 2013 | 10:47 AM
vbnBbnNAng's Avatar
Adding another picture about MPG. Its cleaner picture.
Old May 2, 2013 | 03:50 PM
fartpimpson's Avatar
'07 E550 - current ; '11 Ducati 848 Evo - SOLD ; '07 BMW 335i - SOLD ; '99 BMW M3 - SOLD
Good information to know. Thanks for sharing.
