E-Class (W211) 2003-2009
E500 4matic Suspension Repair
Old Jun 16, 2013 | 08:27 AM
shirley1961's Avatar
2004 E500
I would like to replace the air ride strut on my 2004 E 500 with air ride suspension. The drivers side is sagging by about an inch. Any words of caution or helpful hints? Thanks, Tony
Old Jun 16, 2013 | 09:17 AM
vettdvr's Avatar
03 E500 and Corvette
Buy Arnott, stay stock get life time warranty on the parts do it soon before damaging the compressor..
Old Jun 16, 2013 | 10:43 AM
homeofstone's Avatar
2011 E63, 2011 Hyundai Genesis 4.6 v8, 2013 GMC Denali XL, 1965 Ford Mustang, 2005 Merc. E500
+1 and replace in pairs front/front rear/rear.
Old Jun 16, 2013 | 11:44 AM
2004 E500
OK so both front struts if I understand you correctly! Is it a "simple" replacement, or is there a "special" procedure since they are air ride with adjustable settings? Thanks, Tony
Old Jun 16, 2013 | 04:48 PM
This should help also disconnect both upper ball joints and both sides of the front sway bar. Be careful with air lines and wires.
Video link :
Old Jun 16, 2013 | 08:13 PM
2004 E500
Thank you kindly, Tony
Old Jun 16, 2013 | 08:17 PM
2004 E500
PS: I'll be calling this week!! Tony
Old Jun 17, 2013 | 04:46 PM
vettdvr's Avatar
IF you run into issues ask on this site to solve the issue.
AND DON"T let all the air out of the strut when you get it to install or you might damage the seals. You can reduce pressure but don't go to zero.
