E-Class (W211) 2003-2009
Shaking while accelarating
Old Oct 9, 2013 | 08:56 AM
digimurda's Avatar
CLS500
hi all.
im a ne member with an issue with my 2003 e500
when accelarating at about 20mph+ the car shakes.
when i floor it or accelarate real good it does not do it.
feels and sounds like under the middle of the car.
the transmission shifts perfectly and i dont know what the issue is.
can it be a transmission or motor mount? catalitic converter? flex disc?
please help...
Old Oct 9, 2013 | 09:42 AM
homeofstone's Avatar
2011 E63, 2011 Hyundai Genesis 4.6 v8, 2013 GMC Denali XL, 1965 Ford Mustang, 2005 Merc. E500
Its most likely the center driveshaft bearing and support, but could be the front shaft flex disc. In case of center support and bearing the complete driveshaft has to be removed and when doing so its a good idea to replace both flex disc at that time because of no additional labor. Note: exhaust has to be dropped in order to remove the driveshaft. I had exact same symptoms and did the work/fix on mine about two weeks ago. Took about two hours but I have power air wrenches which speeds up work.
Old Oct 9, 2013 | 10:41 AM
digimurda's Avatar
CLS500
did you feel shuttering from under the front of the vehicle? kinda like a misfire, on my car its really when i tap the the accelarator lightly after the car is 25mph+
Old Oct 9, 2013 | 12:23 PM
The op states its felt in middle of car. If driveshaft center it will be felt in the center armrest when accelerating between approx. 15 to 25 mph. Also if felt more to front then it could be transmission rear mount. Any of these can be checked with car on lift by inspecting mount, flex disc for cracks and shaking the driveshaft by hand.
Old Oct 9, 2013 | 01:39 PM
digimurda's Avatar
CLS500
thanks, i will get this chucked today and will keep you posted.
Old Oct 9, 2013 | 07:47 PM
vettdvr's Avatar
03 E500 and Corvette
It IS hard to tell on line but it might be motor/tranny mounts also.
Old Oct 11, 2013 | 08:58 AM
digimurda's Avatar
CLS500
hi, i got the tranny mount replaced, it was worn.
car drive alot better, just has a slight lil shutter, but nothing compared to how it was before replacing the mount, is there another mount in the front that i should check on?
Old Oct 11, 2013 | 04:30 PM
Did you have the driveshaft checked when the transmission mount was replaced? Did they check the two motor mounts?
Old Oct 12, 2013 | 08:36 AM
vettdvr's Avatar
Motor mounts
Old Dec 5, 2013 | 10:16 PM
digimurda's Avatar
CLS500
Originally Posted by digimurda
hi, i got the tranny mount replaced, it was worn. car drive alot better, just has a slight lil shutter, but nothing compared to how it was before replacing the mount, is there another mount in the front that i should check on?
Actually the car is the same after changing the tranny mount it seemed a lil better but two days later it got worse, do you think it can be the motor mounts?
Old Dec 5, 2013 | 10:50 PM
Did you have the driveshaft checked? bearing and support?
Old Dec 6, 2013 | 09:02 AM
vettdvr's Avatar
X2
