E-Class (W211) 2003-2009
Dynomometer test function???
Old Jan 13, 2014 | 02:09 PM
tonyrobot22's Avatar
2007 Mercedes E350
What is the dynamometer test function for under the settings menu? It's set to off now, but what happens if you turn it on? Any info would be appreciated.
Old Jan 13, 2014 | 06:43 PM
isstay's Avatar
06 E320 CDI (GONE), 14 Jeep GC EcoDiesel, 01 Disco II (GONE), 09 BMW X3 3.0 Si Xdrive
it will disable SRS (Airbags), traction control I am not sure about ABS and your dash will light up w/all different warning symbols for those systems.
Old Jan 13, 2014 | 07:22 PM
jandmtv's Avatar
2010 GL450
Ive never noticed that setting in my car. Maybe its for smog inspections. How do I get to that setting?
Old Jan 14, 2014 | 12:34 AM
AMGAffalterbach's Avatar
2014 BMW M235i
Old Jan 14, 2014 | 01:31 AM
LemonSqueezy's Avatar
14 550 sedan
That is a beautiful .gif my friend.
Old Jan 14, 2014 | 03:03 AM
2014 BMW M235i
And it still works in 2014, damn it's good. Courtesy tanktube67
Old Jan 22, 2014 | 09:40 AM
2007 Mercedes E350
It's under the settings menu on your dashboard. If you press the reset button on your dash 3 times, it'll bring you to a different menu. Under this function, you can reset your service due, if you had the oil changed not at a dealership. But the dynamometer test function is under the system menu. If it does what the guy above said it would do, I'm not touching it.
Old Oct 14, 2015 | 06:29 PM
cwyorke's Avatar
Mercedes CLK350
If it is on Test how do you turn it off?
