ANZ OPTICS CITY LIGHTS: HELP!
Do i need to buy a new resistor?
Also, it looks really good when all the lights at the front are white.
Just have a look at Lemonsqueezy and AMGAffalterbach's set up on this thread.
https://mbworld.org/forums/e-class-w...questions.html
welcome to the forums man.
http://www.ebay.com.au/itm/2-High-Qu...83a39c9&_uhb=1
AMG: im not really planning on changing my FOGs but how easy is it?
do I need to take out the bumper or can i just jack it up one side at a time and slide under?
what type of bulb do I need? cheers mate!
All I did was jack up the front of the car (with the parking brake on of course), put it on axle stands, and take off the bolts that hold in the splash guard (right under where the fog lights are) - it's two bolts in each wheel well on the front side of the wheel, and several underneath the car.
After taking off the splash guard, you'll have access to everything. I drilled into the radiator support brackets on both sides (being careful not to drill into the radiator itself of course) as is recommended on the sticky tutorial on the forum. You then mount the ballasts on those brackets with the provided hardware, and I recommend doing an additional couple zip-ties to make sure it's secure. Then you just wire it up by twisting out the old bulb and hooking up the power from the car to the ballast. No stupid retainer clips like the low beams, just put it all back together and twist it back in!
As for the bulb type the low beams are H7s, the high beams are H7s (not that I recommend HID high beams lol), and the fog lights are H11s.
1. DDM is the cheapest ~$60, and even though others run them I get the feeling their quality isn't up to par, and the product isn't fully supported by them for this application.
2. Morimoto from TheRetroSource, but at $170 +SH it is the most expensive. Nice that they sell the mounting bracket and clear ZKW-R lens if necessary/desired.
3. German made kit from www.hidkitxenonlights.com. Looks nice, but no real W211 reviews, and almost as expensive as morimoto's.
Also hadn't planned on doing my fogs, but you all have me interested. Are your fogs projector? Mine is relfector based.
How much of an improvement is the ZKW-R projector lens swap, and is it necessary? (I'm thinking not).
Thanks for your help.
All fog lights come with reflector housing stock.
As for the ZKW-R lens, there's varying opinions. I was told by one of the local e55 guys that several months after the swap, he still thinks the gains are minimal and wasn't worth the effort. Others on the forum seem to be okay with it.
