E-Class (W211) 2003-2009
Grinding sound and vibrating when steering wheel is turned
Old 09-19-2014, 09:04 AM
Honcho's Avatar
'03 SL55 AMG | 2021 AMG GLE 63s Coupe
I love armchair mechs! Where's the booky so I can place my bet?
Old 09-19-2014, 09:14 AM
vettdvr's Avatar
03 E500 and Corvette
I think it is the knibiling pin connected to the whatyamacalal it bar.
Old 09-19-2014, 09:22 AM
omarzamani's Avatar
2006 Mercedes Benz E350 4matic (Barolo Red Metallic) Appearance+Premium+Sport Packages
Hahahahaha you understand my pain. I just need a correct diagnosis. I'm taking it to mb soon
Old 09-19-2014, 06:22 PM
AMGAffalterbach's Avatar
2014 BMW M235i
You're low on blinker fluid. Problem solved.
Old 02-15-2018, 09:22 AM
atul's Avatar
2013 E350 4matic Wagon, 2002 E320S4 - E-class W210 Wagon 4-matic
Diagnosis?
Did you get this fixed? What was the diagnosis and what repair work was done to address the problem?
Old 02-15-2018, 10:27 PM
ot1
ot1's Avatar
2006 E320 CDI
Grinding noise
you didn’t specify if this grinding noise occurs while turning left or turning right because that can help define where the noise is coming from. My guess it’s a wheel bearing from your description but knowing this are you going to take it into the shop anyway or you going to try and fix it yourself? A bad wheel bearing can be loaded more when turning towards the bad bearing usally it will make more noise when perforrming a 90° turn. Also if it only occurs in one turning direction the tire could be rubbing on something that came loose also pay attention as to whether not you are applying brakes while you are turning
Old 02-17-2018, 10:34 AM
  #32
Sleeper Benz's Avatar
W223 S500 LWB 4-Matic, W222 S450 LWB 4-Matic, W211 E500 4-Matic Wagon
Thread starter hasn't posted since 09-19-2014, 09:22 AM. I doubt they are still here. Good tip on the bearings going south though.
Quick Reply: Grinding sound and vibrating when steering wheel is turned
