Camber is too negative -- shop says something is bent? Help...
I took it to the shop to get aligned this morning and the shop just called me...they told me -1.5deg camber driver and -2.5 passenger. (I used a level gauge and that's what I read too, but I thought it may have been just my gauge or garage floor etc).
He said that something must be bent somewhere. He is setting the toe up so its driveable, but obviously something is wrong on that side.
Any ideas what to do or where to look? Never ran into this before...
I have "googled" on the subject. I want to know if there are any particular items to check specific to the W211 that could be bent.
I need advice here. The car shows no signs of any accidents. Original paint, bumpers, fenders etc.
The bolt kit allows for 0.4deg +-...I am -1.0deg out. Somethings bent. This isn't an adjustment issue as I have already mentioned
You can trade caster for camber. I.e. change caster by 0.3 degrees and the camber will move 0.3 degrees in the opposite direction (e.g. less caster gives you more negative camber, more caster gives you more positive camber).
In your case, I agree the camber is really off. The right-side caster is "good enough for government work" compared to the left side but the right side lower control arm needs to be pulled in somewhere in the neighborhood of 1 mm (or the upper control arm needs to be pushed out ~1mm). At this point, I'd be tempted to say cut your losses, purchase and install a K-Mac bushing kit in the front lower control arms, and correct the camber.
Afterthought: have you checked to see if the right front is marginally lower than the left front? A sagging suspension on one side will increase negative camber but not greatly affect caster. Measure from the fender roll to the center of the hub or to the ground. Perhaps raise the front right a bit? A few millimeters will translate to several tenths of a degree of camber. I believe (but I haven't tried it) you can connect the car to a diagnostic system and individually adjust the front suspension height. (Assuming Airmatic Suspension)
Keep trying and please post your solution.
THERE IS ONLY TOE ADJUSTMENT OEM. SO YES – AT K-MAC WE SAW THE NEED AND MANUFACTURE FOR THE 4MATIC (AND VIRTUALLY EVERY OTHER MODEL 1968 TO 2015) FRONT LOWER CONTROL ARM INNER CAMBER BUSHINGS ALONG WITH SIMILAR THRUST ARM TO CHASSIS CASTER BUSHINGS.
THE UNIQUE K-MAC patented design provides up to 3 times the adjustment range of the inaccurate (one only position) offset fluted bolts.
It means you can now have precise, single wrench ongoing adjustment capability. On car – no labour intensive disassembly each time – accurately (under load) direct on alignment rack.
Allowing to return to factory specs after curb knock damage, altering height, load carrying, fitting wide profile tires/wheels or if wanting to alter/adjust alignment specs for track days!
Fixing it right the 1st time. Resolving steering pull, costly premature edge tire wear. No more ongoing visits to dealers or alignment shops because of not being able to obtain precise adjustment.
Front K-MAC P/N (W211 4matic) 502416 $480.
For the rear (also only Toe adjustment OEM) similar lower control arm bushings for precise Camber adjustment, along with additional Toe adjustment to compensate for this new Camber facility.
Rear K-MAC P/N (W211) 502526 $480.
Added bonus is the 4 front and 4 rear bushes replace the highest wearing suspension bushings with twice the load bearing area and improve brake and steering response.
All kits come with bush extraction/insertion tubes.
This month’s special delivery price for MB World members USA/Canada - $30 one kit or $40 front and rear. Payment can be made by Visa, MasterCard or PayPal.
See link for out latest 2015 catalog http://K-mac.com/mercedes/
For reference though, does the kit include what looks like the pressing tool to get the old bushings out and k-mac ones in? Or is that additional?
Diagram below sets out the ease of adjustment.
Also forum member HeissRod https://mbworld.org/forums/w211-amg/518431-k-mac-bushing-install-guide-w211-airmatic.html has kindly provided step by step pictures re use of the pressing tools included re removal and replacement of the front bushes.
For the rear the actual bushes are not in arms but frame so this bush extraction tool supplied is designed so rear can be installed on car.
See link for our latest 2015 catalog http://K-mac.com/mercedes/
