E-Class (W211) 2003-2009
Rubber gasket at the bottom of the windshield
Old Nov 9, 2015 | 09:39 PM
Ray R's Avatar
2006 E320 CDI
I recently had the windshield replaced on my 2006 E320 CDI. The rubber strip at the bottom of the windshield got sort of buggered up with cracks, small chunks missing, etc. So I'd like to replace it. Is there a DIY process for replacing that rubber piece? Anyone have the needed part number?
Old Nov 10, 2015 | 12:47 AM
kajtek1's Avatar
1922 Ford Model T / no OBD
I check my EPC and it is easy to confuse the part.
Since this is likely dealer-only part, I would go to a dealer with VIN to match it.
Or take the old part out and read the number from it.
Old Nov 10, 2015 | 10:51 AM
Ray R's Avatar
2006 E320 CDI
I looked at EPC as well and couldn't positively identify the part.
The DIY heater control valve sticky shows the removal of a "plastic trim panel" that seems to have that rubber gasket. But it doesn't indicate if the gasket is part of the trim panel or a separate piece that can be replaced by itself.
Old Nov 11, 2015 | 06:45 PM
Ray R's Avatar
2006 E320 CDI
It was listed under "heating and ventilation" - "water baffle with intake shell". "Seal at cross member" part number 2118311198. Not very intuitive. The best news is it's only $10.50 from the dealer.
I have to wait a few days for it to arrive. Then I may do the install myself.
Old Nov 13, 2015 | 05:59 PM
Ray R's Avatar
2006 E320 CDI
Well, that $10.50 seal is just a foam gasket that goes between the plastic cowl cover and the metal cross member under the windshield. Not the right part.
I took the plastic trim piece (cowl) off the car, and that rubber strip is integrated into it. So I have to buy the whole piece in order to replace the rubber strip. It's $117. Ugh.
For reference, the part number is A2118301213 for the E320 CDI. Other models may use a different part number, so it's probably best to check yours before ordering. As usual, the part number is stamped on the back of the part.
It comes with the 8 mounting tabs and the 3 rubber grommets for the windshield wipers. So if you break a few while taking your old one off; no big deal.
Old Mar 11, 2016 | 10:19 AM
DiegosAnotherR1's Avatar
e55
do you have any pictures of the part? Was it hard to replace?
Old Mar 13, 2016 | 08:21 PM
Gersh320's Avatar
E320 & X166
pictures please
Old Mar 17, 2016 | 02:40 PM
starbrite's Avatar
2004 E320
Originally Posted by Gersh320
pictures please
https://mbworld.org/forums/e-class-w...ml#post6620568
Old Mar 18, 2016 | 09:18 AM
Gersh320's Avatar
E320 & X166
Thank you!!!!
Old May 9, 2017 | 05:26 PM
ben73's Avatar
W108 3.5 - 2005 E55
I'd like to replace this part on my 11/04 E55 as the rubber strip that goes along the bottom of the windshield is starting to crack.
My existing part is marked as A211 830 01 13.
When I search for this part at the usual online parts retailers, it comes up empty.
Ray R posted above that A211 830 12 13 fitted his E320 CDI.
Are all W211's the same in this area?
Has my part number been superseded perhaps?
Old May 9, 2017 | 06:55 PM
ben73's Avatar
W108 3.5 - 2005 E55
Oh... I know the difference..
Mine is RHD.. There are a few components near the firewall that make this part different.
Old May 9, 2017 | 08:16 PM
BenzVince's Avatar
09' E350, 01' Maxima SE, 93 Nissan Maxima SE, 1987 Nissan Maxima SE
you know, I was wondering the same thing since I have the same problem, unusual for MB to have "rubber rot" unlike other makes I have owned never had issue. I wanted to replace that rubber piece, but I might well get the whole thing if it's what it takes.
Old May 10, 2017 | 11:20 AM
konigstiger's Avatar
'71 Pinto
2118301213 is current, replaces 2118300013.
Old May 10, 2017 | 11:23 AM
'71 Pinto
09 e350 part # is 2118300513.
