E-Class (W211) 2003-2009
command center dead
Old Dec 16, 2015 | 09:33 AM
glwilldo912's Avatar
2006 e-350 base sedan
Question command center dead
My command center just stopped working. I have a 2006 e-350. i pulled and checked fuses in the trunk and passenger area, no luck. I saw a comment that the command center had a fuse in the back of the unit?? not sure how to get to it or if that's the right approach. Any help would be greatly appreciated.
Old Dec 19, 2015 | 07:04 AM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
moved to W211 forum...
Old Dec 19, 2015 | 05:59 PM
Gersh320's Avatar
E320 & X166
Replace the fuse in the rear SAM even if it doesn't look burned. But leave it out for 10 minutes or so first.
It is fairly easy to remove the COMAND unit but that's a different topic and last resort.
Old Dec 22, 2015 | 08:52 AM
command center dead w-211
thx for the response, however no luck. Pulled both sets after the rear did not work, front and rear of fuses 3,6 26,28 and checked continuity of all. No difference. saw a u-tube on removal, I guess that would be the next logical thing to try, see if that fuse is blown.
Old Dec 23, 2015 | 04:22 AM
burgca's Avatar
'97 S500 Coupe, 2016 AMG S63 Coupe, 2007 Audi Q7
Here is a Command troubleshooting video
Old Dec 28, 2015 | 09:18 PM
4thtennenbaum's Avatar
E320
Sorry to hear GL. I was hoping I could shed some light... Mine died in July and I just got it fixed a month ago.
I went to the dealer for another reason, and they gave me the part number and cost/labor and it was $1380.
My local MB specialist quoted me $1000 on a used part. They are supposedly plug and play, so he removed it and put in the new one.
I could have chanced it and probably got a used one myself and replaced it for $400 or so.
What kept me from that was if the Comand unit isn't turning on, there may be a fault component. The components (like NAV and CD changer) can keep the head unit from turning on.
I'd contemplated replacing it with an aftermarket, but found out the car has a fiber optic loop, so every bit of stereo wiring would have to be replaced. Best Buy said on the low end, $1500 for just wiring.
You can also pull the unit and send it into a repair specialist for a diagnostic or replacement.
http://mandbspecialist.com/
http://www.mbdoctor.com/
Sorry to hear. It's a crap thing to have a problem with. I went without it for about 5 months.
Old Jan 15, 2016 | 08:39 PM
palldo's Avatar
W211 E270CDI
Hey guys, i have changed the main battery on my w211 and since then i am not able to switch on my command system. Do you have any clue how to reset it?
Old Jan 16, 2016 | 02:32 PM
burgca's Avatar
Did you check the fuses?
