Panaramic Moonroof questions
**SOLD***2003 E500
Panoramic Moonroof questions
A couple of times my moonroof has lost sync and gone into fail safe mode. If I reset it, everything is good. This has happened about four times now since I have bought the car. My question is:
Has anyone else on this board had this problem, and or know what causes the the roof to get out of sync? The good news is the roof always closes, albeit slowly and with the safeguard stutters. Just curious.
Thanks,
Randy
Thanks,
Randy
04' E500 w/Appear. PKG, Panorama Roof
No issues with mine other than it seems to have a low "groan" sound in the final close movement. Any way you could be opening or closing and while doing so- inadvertly holding the switch in either position for too long past finish ? I think that the roof can be confused if the switch is held.... Just a thought....
**SOLD***2003 E500
Brought my car in for service with a heater issue, and mentioned the sync problems I have been experiencing occaisionally with the roof. Turned out to be a low voltage issue in the overhead console. This was causing the computer that controls the roof to have the sync memory loss as well as the sensors for the A/C to be out of whack and not allow the heater to come on at all. replaced the overhead console and all is good. Just FYI for all with the roof is you ever have similar issues.
Regards,
Randy
Regards,
Randy
1 Post
07 M6, 05 Noble, 01 S4, Smart ForTwo
No problems, except I have a creeking sound when I drive over speed bumps, only when the roof is closed.. must be a rubber seal making noise. Otherwise functions without a hitch.
2012 CLS
Brav, my roof does the same and I found that getting the dealer to lubricate the roof channels etc cures it for a while.
In UK you realsie just how much the roof flexes when it freezes, and so it follows that a bit of lubrication will sort it.
Marc
Marc
1 Post
2003 Citron Green C230KMT
dont know how much different the pano roofs are on the E and C but mine has never given any problems as far as fail safe. they needed to lube the rails 2x though because the roof will stick, especially after washing the car and if i dont open the roof and let the water dry while the roof is closed. do you experience that same issue with the W211 pano roof.
