Check engine light burnt out
I suppose the previous owner before I got the car from my dad has tempered with the check engine light . Is it just as simple as replacing the bulb or have they done some irreversible damage?
I found out by pulling some codes it had and they weren't old stored codes, they came back just a while after driving for a bit.
Do I have to buy a new dash and code it to my car to match miles etc?
Instead of dealing with the problem, you take the CEL out. Who does that?
You can pull IC to check internal condition. This site discusses backlighting repair via ribbon cable for CLS (same as 211): https://mbworld.org/forums/cls-coupe...hting-fix.html - read thread in its entirety.
What's the easiest fix? Does a new dash need to be coded to the car? Or can I just find a close enough mileage dash and put it in without any additional coding? Thank you for your responses so far.
I'm not so sure though. I've had some of my friends change IC in their cars (BMW, Mercedes Sprinter) due to different reasons and if they were lucky and find a really close mileage cluster on eBay, all it took was unplug old and plug in new one; done.
What am I missing? I'm willing to spend 200$ for used cluster but def not 2000$ to get new one from the dealer.
Any picture of LED ripped off? Would that be so hard to fix?
Will this work with any year cluster? Or am I better off looking for the same year as mine?
