E-Class (W211) 2003-2009
W211 Bluetooth
Old Jan 19, 2017 | 07:40 PM
eugeni74's Avatar
2005 E320 CDI
W211 Bluetooth
Please advise best way to have bluetooth for phone and music?
Old Jan 19, 2017 | 09:01 PM
RCPDesigns's Avatar
2007 e350, 2013 C250, 2004 C320, 2003 C320, 1998 CLK 320
Search the forum. You need a "puck with a tail". https://mbworld.org/forums/e-class-w...-question.html
You have to go to the dealer to get it version coded after you install it.
I know with our 2004 you cannot get bluetooth music. You need to use the AUX port that is in the glovebox to connect your phone to play music.
Old Jan 19, 2017 | 09:47 PM
rapidoxidation's Avatar
2013 ML350 Bluetec
I've found that a carefully run Aux cable from the glovebox works quite well for music and for phone. Not quite as convenient as you have to plug the phone in and you get to see a wire, but a vent mounted phone carrier will allow for easy control and surprisingly good clarity on both ends of a call.
Old Jan 20, 2017 | 01:02 AM
cetialpha5's Avatar
I don't think you can get bluetooth music until the 2011 E-350. Even the 2010 didn't have it, but it could be enabled. No bluetooth music for W211. I kinda like the ipod touch cable better than bluetooth.
Old Jan 20, 2017 | 09:02 AM
burgca's Avatar
'97 S500 Coupe, 2016 AMG S63 Coupe, 2007 Audi Q7
You can use a Bluetooth adapter through the Aux port for Music and phone if you don't want to upgrade the audio system
https://mbworld.org/forums/e-class-w...at-s-nest.html
Old Jan 20, 2017 | 09:35 AM
arto_wa's Avatar
2008 E320 BlueTec, 1980 300 SD
For music I bought used iPod Touch from eBay vendor for $50 and connected it to the Aux wire that was already in the glove box. The connector is the flat type used before lightning type.
For me it works best with the iPod in the shuffle mode!
My iPhone 5S paired easily with the Bluetooth puck that came with the car and was already in the center console.
The phone works fine handsfree when receiving calls but to make a call I pretty well need to select the number to call from the phone itself.
Yes, it's possible to select number to call in the instrument cluster with the steering wheel buttons but it's awkward!
You should be able to find some info here:
http://wireless4mb.com/
Did your car come with factory "mobile pre.-installation" option (code 389 in my car)?
Old Jan 20, 2017 | 02:03 PM
cetialpha5's Avatar
Bluetooth changed with the year. It's probably the same for 2007-2008, maybe 2006 as that's when the facelift happened. I think 2009 was a newer version of NTG so it was built in. So I'm not really sure if all that applies to a 2005. But yeah, the ipod touch is the best way to go for me. I run spotify on it and just bring it home once in a while to sync up with the latest playlist. It has the older 30 pin cable although I think there's a newer lighting cable. Ipod touch 4 is the best way to go as it's a $200 player that now goes for $30-$50 on ebay, craigslist. I think I have over 1000 entries in my phone book so I always get a message that says the address memory is full, I think MB limited it 250 entries so I never use the controls on the steering wheel, it'd take forever. Thankfully my Android phone has voice control and it's usually pretty good about selecting the right number when speaking out loud. The best part of using the ipod cable is that you can control the music being played from the steering wheel, if you just use the aux input, you don't have steering wheel control although the volume should still work.
Old Jan 24, 2017 | 10:28 AM
arto_wa's Avatar
Well, the OP asked for free advice and he got pretty good advice but we have not heard from him since...
Old Jan 24, 2017 | 09:31 PM
eugeni74's Avatar
2005 E320 CDI
Thank you for all responses! I normally use the AUX IN the glovebox for music, just got a little tired of plugging in every time. It also works for the phone, but still using the phone's microphone. Car doesn't come with factory puck, or at least I didn't see one. Have been looking into some of the of the aftermarket android head units on ebay. If one of these can also pull the google maps on from the phone on the screen would be great! Don't need the DVD player, that's stupid. But one of the posts is talking about re-wiring the amp in the back. That would be a pain, and don't want to do it. Willing to replace the whole head unit if I don't have to mess with the amp in the back.
Old Aug 19, 2018 | 12:49 PM
YVR's Avatar
YVR
2006 E350
I'm a latecomer to this thread... I've done some searching but still can't figure this out,
Just purchased a 2006 E350. It has COMAND but not the 389 package referenced earlier. I can't find any audio connectors aside from the aux in located in the glove box. What are my options for streaming Bluetooth music? (Phone calls is not a requirement for me.)
Thanks in advance!
Old Aug 19, 2018 | 03:33 PM
kajtek1's Avatar
1922 Ford Model T / no OBD
When I know that playing music via command center in 2006 model is not going to be easy, I wonder if anyone tried one of those FM transmitters?
You plug it into headphones socket on your android, set the same FM band on it as well as on the radio and fire up.
I have 1 of those $10 adapters that I bought for my RV to play video sound from laptop via central speakers and after couple tries, found a model who works well.
Used it also in my house, who has central audio with amplifier upstairs, where playing TV sound would take running over 100' of ugly cable.
The transmitter works just fine.
Old Aug 21, 2018 | 04:37 PM
EuroDriverSD's Avatar
2016 E350 Sport; Mom Wrecked the 2008 E350; sold the 2002 C320
IMHO, best approach is to install an aftermarket head unit. I tried the BT puck/aux cable combo and got sick of all the quirks. I then went aftermarket and never looked back.
I don't know much about the Chinese android units but there's a few threads and how-to's here on the forum. If you want to go with a mainstream brand head unit, you're going to need a NAV-TV or Opti-1 module (it's a fiber-optic to analog converter). It's a bit expensive but well worth it. It makes the conversion plug-and-play without the need to rewire anything.
Here's the thread on what I did: Bluetooth Upgrade
Old Aug 21, 2018 | 07:52 PM
arto_wa's Avatar
I spent $54.99 on CoolStream Bluetooth receiver about year and half ago and it has worked flawlessly with iPhone in my 2008 W211!
File Type: pdf
Old Aug 21, 2018 | 10:37 PM
kjb55's Avatar
2025 AMG E 53; 2018 GLC300 4Matic; 2003 360 Modena
Kinivio BTC450
i hardwired in the Kinivio BTC450 in my 2006 E350 with COMAND. It works flawlessly, streams music via Bluetooth and the hands free phone works great.
Old Aug 24, 2018 | 09:49 PM
YVR's Avatar
YVR
2006 E350
Thanks everyone for the suggestions! I will look into all those options!
If I went aftermarket, does anyone have a good head unit that fits well into the space but isn't a touch screen? I dislike touch screens in cars as I have to take my eyes off the road too much to operate them.
Now back to my current task of repairing the centre dash speaker (from my internet readings, I just have to glue the speaker back together...).
Old Aug 25, 2018 | 01:11 PM
arto_wa's Avatar
If I went aftermarket, does anyone have a good head unit that fits well into the space but isn't a touch screen? I dislike touch screens in cars as I have to take my eyes off the road too much to operate them..............
I would not want to mess with the fiber optics in-between the factory head unit and what's it connected to in the trunk etc. in the car, but hey that's just my opinion.
If you search this site, you should be able to find info on how to connect "iPod cord" to the factory head unit and plug in Bluetooth receiver like many of us have done. If you are not iPhone user no problem, you can buy used older iPod pretty cheap and play music from that.
In my experience, iPhone (5S) has much better control for playing music then iPod (5th Gen.).
https://mbworld.org/forums/e-class-w...ice-works.html
I suppose Android unit would also work!
Old Aug 25, 2018 | 01:20 PM
cetialpha5's Avatar
Hmm... I'm still using a 4th gen ipod Touch. Works fine. I just start it on my spotify playlist and then I can move up and down the song list and control the volume from the steering wheel. I just have to bring it inside every 30 days or less in order to sync the playlist.
Old Aug 25, 2018 | 01:27 PM
arto_wa's Avatar
Sure no problem, just my personal preference based on having both iPhone 5S and iPod 5th gen.
Old Aug 25, 2018 | 01:31 PM
YVR's Avatar
YVR
2006 E350
That would be pretty awesome and is probably my preferred solution. But I've been unable to find conclusive information of whether that's possible. The dealer says no, but it could just be that MB no longer produces the relevant parts. I've seen references to iPod connectors in gloveboxes, but mostly from people that already have one.
I have a headphone AUX jack in my glovebox, no iPod connectors. Can I tell if my head unit can accept some sort of iPod adapter? Is there a specific adapter I can get which will fit the head unit and leave me with an iPod connector (doesn't matter new/old; I can get adapters to solve that)?
Thanks in advance!
Old Aug 25, 2018 | 01:54 PM
arto_wa's Avatar
.................I have a headphone AUX jack in my glovebox, no iPod connectors. Can I tell if my head unit can accept some sort of iPod adapter? Is there a specific adapter I can get which will fit the head unit and leave me with an iPod connector (doesn't matter new/old; I can get adapters to solve that)?
Thanks in advance!
Please read post #8 by Strigoi regarding connecting iPod cable to the head unit:
Maybe he can help you more?
My car came with both iPod and Aux connections already installed in the glovebox. (Actually I have never tried the Aux connector and do not know if it is wired or not?)
Old Aug 25, 2018 | 02:09 PM
arto_wa's Avatar
Further to the above:
Apparently there are also a Bluetooth receivers that connect to the Aux connector, as mentioned by burgca in a post #5 above.
Old Oct 22, 2018 | 01:24 PM
YVR's Avatar
YVR
2006 E350
Thanks everyone for the suggestions! Sorry for being slow to circle back here. From posts and research online, it looks like there are three main options:
  1. bluetooth receiver that plugs into AUX
    • Pro: cheap; easy to install
    • Con: wires hanging on front of dash; need to remember to turn off BT receiver
  2. find wiring to adapt factory head unit for iPod
    • Pro: integration with iPod
    • Con: there seemed to be variations on parts and compatibility between adaptors, head units, factory installed cables, and phones and I couldn't definitively determine what would and wouldn't work without acquiring and trying; cost; not necessarily easy to install
  3. replace stereo head unit
    • Pro: modern technology; ability to get android auto and apple carplay; modern navigation
    • Con: costs a lot more than option 1; several hours of work to install
For now, I've gone with option 1. I purchased
this TaoTronics Kit this TaoTronics Kit
and have been using it for over a month. It works pretty well considering it's so cheap (<$25).
