2005 E320 CDI Fuel Filter Hose Size.
http://www.pelicanparts.com/catalog/..._pg1.htm#item1
The big fuel line that about 6-8 inch long is a AN8, while the other ones are a AN6. Decided to replace the fuel line with Stainless Steel Nylon Braided. Would have gone stainless with stainless but people said online they don't bend as well.
Will take better photos tomorrow have one line left to do the back one near the egr.
Also not going to touch the last line by the EGR, line looks fine plus looks like the biggest pain to remove.
regards,
Peter
When something meets AN specification its of highest quality, and undergoes QA and QC.
A fitting or bolt will be a least 4 times more expensive than non-AN bolt.
Hose clamp 14.5-15.5mm 004 997 20 90
Hose clamp 13-14.5mm 006 997 18 90
I didn't get the factory style clamp because the aftermarket hose was thicker then stock, I don't think it will have enough clamping force to stop it from leaking. I can't say for sure since I just went straight to hose clamps .
And next time you are under the cover maybe cut those stainless hose wires before you poke yourself and bleed to death, or worse get an infection and they have to cut off your favorite hand.
