Alarm keeps going off
My 2009 e350 sedan alarm keeps setting off by itself. Today was the first time I drove the vehicle in 5 days. Parked the car and 4 separate times the alarm is going off.
What could be wrong here? Help needed. Security in my office building keeps Calling me!!
Received 4,441 Likes
'71 Pinto
Check siren for internal corrosion here are compatible part #s for replacement.
Courtesy lights also won't turn on doors or overhead. Could this be more than a siren
'71 Pinto
Then you also need to check the hood switch, (130 in diagram) part # 2038219251.
The alarm has an internal battery that fails with age and leaks on to the circuit board. Remove or replace the alarm. It's useless so I just removed it. It's located behind the front left fender liner.
https://mbworld.org/forums/sl-class-...y-fix-diy.html
Originally Posted by tjts1
The alarm has an internal battery that fails with age. Remove or replace the alarm. I just removed it. It's useless.
